boat help
hi does any one have plans to make a boat like this here ?http://www.youtube.com/watch?v=4BSv0...eature=channel
RE: boat help
There's Dougs woody plans, alternatively you could look up Zipkits website & buy a wooden kit. That hull looks like a cross between a crackerbox & a deep vee.
http://www.zippkits.com/ The zipp kit option would be easier & cheaper than buying all the wood & cutting it up. you also get building instructions with them. |
RE: boat help
thanks i like this one http://www.zippkits.com/ my ? is what does the kit include ? is it just paper and u trace it to wood ?
RE: boat help
RE: boat help
The kit includes all the wood pre cut, all you will need is glue, clamps, sandpaper, weights, paint and time. You will have to buy all the hardware like rudder engine etc separately, some of it you can get from Zippkits though.
RE: boat help
aahhhh ok thanks
RE: boat help
here's a list of everything you will need to build a boat
List to build a boat - Hull - Radio box - Pool noodles (floatation) - Rudder - Stinger/strut - Strut Bushings (if not a roller bearing strut) - Thrust washers (for square drive) - Flex - Stuffing tube - Stuffing box/T-bar (hull dependant) - Prop nut - Drive dog - Engine - Engine mounts - Collet - 4-40 Push rods - 4-40 push rod ends (x5) - Throttle bell-crank (if not included with engine mount) - Pipe - Manifold - Header - Pipe stop - Pipe mount - Cowl locks - Steering servo - Throttle servo - Receiver (with failsafe) - Battery (Velcro tie-downs) - Servo mounts - switch - Nuts/bolts/washers - Antenna tube - Antenna mount - Fuel bag - Fuel line - Water line - Water outlets - Zip ties - Fuel bag hooks - Fuel filter - Plug for fuel filler line - Boat stand Optional (hull dependant) - Turn fin (Hydro) - Trim tabs (Crackerbox) - Skeg (Crackerbox) - Water pick ups (if not in rudder) - Lead Weight |
RE: boat help
i should just look for one all ready built lol
RE: boat help
And I missed push rod/radio box seals.
There's nothing like building your own boat. There's no better way to learn how it all works. |
RE: boat help
RE: boat help
what does a drive dog do
RE: boat help
It connects to the prop shaft and is notched to match the propeller so that it will turn the prop and not let it spin on the shaft.
hang on I'll post a pic |
RE: boat help
1 Attachment(s)
drive dog fits into grooves on the prop
RE: boat help
ok thx
RE: boat help
another question not really related
can you reverse a weedy engine |
RE: boat help
Let's say that it can be done but a big hassle. You have to find a recoil that will turn in the opposite direction thne reverse lay flex cables and left rotation props. For a weedie engine it's simply not worth it. Those that have the serious money do it.
RE: boat help
you would probably be less out of pocket by picking up an RCMK RX254-R, it's already counter rotated, the RX254 is the normal rotation version. I don't see them on Gizomo's website though. You can look at them at www.RCMK.com
RE: boat help
ORIGINAL: Ron Olson |
