Twin .12 Texan video
TX
Friends, I finally have a bit of video!!! I was pretty happy with the way it ran again today, but of course a new issue showed up. The afterrun oil I use is very slippery (Mobil Jet One) and if I don't clean the pipes and couplers really good before I put it together, the coupler slides off the pipes. It did it each run today so I never got more than a few laps. But I was happy overall. I was running the largest set of 1440 props Mark built for me. You can't tell in the video, but the water was really bumpy on the left end and back straight.
http://www.youtube.com/watch?v=r0GQMveZHc4
Anyway, not a great video, but I'm happy the boat is coming around.
Glenn
Glenn
TX
RE: Twin .12 Texan video
Craig, no I hesitate to make a guess at the speed. I don't consider this a very fast boat yet...it is certainly not as fast as my single .12 heat racing boat. But that is OK as I didn't really build it for speed, just for the cool factor (and I AM happy with that).
GQ
GQ
TX
ORIGINAL: toyotatruckin
Looks good, like the retrieve boat to, get your stalled RC / catch a bass!
GQ
TX
Pain....I figured the PEACE OF MIND knowing if your model stalled out while you were in a REAL boat would be all that you needed to have more pleasant runs.....
TX
ORIGINAL: res3567
Glenn
FL
Looks good Glen I Love the sound of the Twin Engine set up.
I have running Out the John Boat down to a Science, I don't have any Nice Club Ponds to run at and Most the ponds I do run at have tons of weeds around the edges,,, Dang FL Swamp,,
You should check out the SANYO Xacti line of HD cameras they have some nice vidoe cams for a decent price, or atleast compared to the Other HD cameras out there with the big optical zooms and such. There small and real easy to operate. Check out a couple of my vids and you'll see what I mean.
TX
ORIGINAL: Ron Olson
Looking good Glenn! Don't sweat the video as I can see and hear it well enough.
You're not blaming Donna are you? I won't tell.
Glenn
Glenn, Sure looks fast to me!
BTW, Pulling one head shim and running no water on my JAE 21 Novarossi 5-port did the trick for me, running 25% nitro and 55 degrees out. Thanks for that advise that you gave me awhile back, it really woke the engine up, still allot of tuning still... Novarossi makes a great motor.
TX
ORIGINAL: Blackout
Glenn
Glenn,
What are good running temps for all your Nova's And what temp's are the ones to stay below. I was with Blackout when he ran his Nova , pretty Fast run. I'm not sure if we had the radar on ,your hull Craig. Or did we? I remember 49 mph on what hull I'm not sure. I better get me a temp gun. I'm a believer in temp guns. NOW I've also heard a few other guys swear buy there temps. Just another tool that works. I guess I'll find out this Spring. I thought that speed on them twins wasn't bad. Glenn.
We need a laptop to start keeping imfo. Air temp/ water temp / engine temp. Who would of thought. laptops , water gauge. My tool box is getting heavy.
Happy Holidays
Neil
Happy Holidays
Neil
TX
ORIGINAL: advanced builder
Glenn,
Happy Holidays
Neil
Glenn,
Happy Holidays
Neil
If you check out this video it shows the temp stuff pretty good and you can see how I check it at the end of the run. This motor temp was just at the high end of being right on.
http://www.youtube.com/watch?v=k2YAcAgm42Y
Glenn
Glenn,
Happy Holidays
Neil
Glenn,
Happy Holidays
Neil
We radared my JAE 21 at 55 mph, but that was the very first time it was running descent. That was on 25% nitro and a Zippkit 1450 prop. My mono radared at 49 mph.
I have a infrared pyrometer you can borrow when we test at my place again. From what I have read, 175 to 200 degrees is good. The sleeve in ABC engines need to expand like designed and that won't happen until the engine gets up to temp. Better to cool the engine by running rich than cool with too much water. In the end you will get more power.
ORIGINAL: Glenn Quarles
Neil, I have no idea of what the temps are...I just use the finger test. If I can hold my finger on the head for more than 3 or 4 seconds then it is to cold, if I can't touch it without getting burnt then it is to hot. If the boat sags or quit while it is running, then it is to hot. There is a HUGE difference between running a motor to cold and running one that is warm enough.
Glenn
Glenn,
Happy Holidays
Neil
Glenn,
Happy Holidays
Neil
Glenn
Your finger test works good. I have done both and using your fingers is pretty accurate and allot easier. It's hard to take the pyrometer in the retrieve boat....
I did hear about the "SPIT" test. If your spit on the head button & bubbles it's too hot. infrared pyrometer that's too easy. LOL 55 MPH Craig , You got me beat. I'm 53mph down in Elmira. I can't wait. buddy.
just don't spit into the wind. OR do a#1 into the wind. [X(] I'm not sure if they censure pee pee ,Here
