Slipping Prop
Slipping Prop
I just bought a new Proboat Shockwave RTR. When I run it, I will give it gas and it just revs up but doesn' t go anywhere. I noticed that the set screw in the drive shaft right behind the prop keeps coming off of the "flat spot" and the drive shaft just spins on the inside not allowing the prop to grab. I have tried lock tite but this has not helped. Has anyone had this problem before and if so, how did you fix it?
An information is deeply appreciated.
Shockwave55-
Shockwave55-
Slipping Prop
2 ways to fix this.... file a lager flat surface on the shaft or use a drill with a bit the same size as the set screw, drill into the shaft just enough for the set screw to lock onto the shaft.
One more thing to check for, at the end of the set screw, there should be a sharp edge or small rigges, if either of these are wore off, the set screw will not bit, and the vibaration will make it back out.
Loc tite keep using it, the blue works better on the small screws. The red works too good.
Slipping Prop
the first answer was a good one, I prefer the drill method but if you are not able to do it, flining it flat will work, Dont get carried away, this can be a good breaking point on a shaft. I still prefer red on the shaft. I dont want to reuse a drive dog anyway. Ken
Slipping Prop
Out of the box the Shockwave is everything Proboat says it is! Fast, amazing handling, Great looks! I am very satisfied with the boat. However, the instructions that come with it could be better and if your new to the hobby like me, that can mean alot!
-Shockwave55
-Shockwave55
IL
Hmmmmmm..
Just remember, flat must go with flat. If you drill into the shaft for the set screw then it is ok for the bottom of the set screw to be pointed but if you file a flat spot then so should you the bottom of the set screw. A set screw with a pointed end will not seat against a flat filed spot and will eventually loosen up due to lack of contact. GoodLuck..
