NovaRossi motors?
NovaRossi motors?
Which motor is the better motor for a jae 21 rigger. The Novarossi5 port or the7 port? And for only 50 or so dollars more i can get the7 port. My goal is to make the Rigger as fast as i can!!!
RE: NovaRossi motors?
I you go back and look at the spec's the 35 plus has a higher rpm range. Ask Glenn his hybrid .21 is also a good choice. All Hobbs has the new powerhouse in the A-spades .21 the name I can't recall at the moment. very pricey. Glenn has more than his web site shows so ask . He may have his own .21 pipe also. The Rossi header I'm not a big fan of. heavy with fins.
I'm with AB, contact Glenn Quarles, he will sell you his fastest Novarossi. And then you will need a matching prop and tuned pipe....
