parts wanted
parts wanted
hello my grandsons and i are new comers to this site. we are looking for parts for our nitro boats we appreciate any help in finding parts.we need a .18 marine and exhaust also radio box.we also need motor mount for dumas scarab deep v for ops.67 3/16 FLEX CABLE. WE appreciate any help thank you.
RE: parts wanted
3/16 drive-lines are old school and most guys have gone to 1/4 " drive line with a 3/16 step-down on the shaft,for all proper props. You can twist up a 3/16 cable in a flash. If your not too far along on the build Id think about going to 1/4 " driveline. You wallet will love you. really I have redone most of my .67 hulls My Dumas Atlas Vanline still need to be updated. 3/16" was all we had for a long time. Until gas showed up ,now everyone going to gas and dumping big nitro engine. Nitro fuel and glow plugs were cheap. A .67 can eat up 16 OZ in a run . Some of us still run big nitro and love it I also run gas and find it more and more easier. No clean up to speak of. pull the cable and open your radio box. Done. No after run oil no nitro to clean up. I just seen a guy twist up a 3/16 cable in 1 min. Last week
RE: parts wanted
How's this:
Exhausts http://www.macspro.com/
.18 Engines http://www3.towerhobbies.com/cgi-bin/wti0093p?&C=GCU
Radio Box http://www.aeromarinerc.com/index.ph...mart&Itemid=53
Drive Shafts http://www.aeromarinerc.com/index.ph...mart&Itemid=53
Engine Mounts http://www.aeromarinerc.com/index.ph...=110&Itemid=53
I would go with the square drive flex cable, much easier to set up than a standard in my opinion
RE: parts wanted
I found a set of mounts You may need to drill and tap a set of holes for the OPS the mount bolts down into hardwood
Joe over on Zippkits has some good deals on his hardware and drive-lines. http://www.zippkits.com/
I also have a NIB .12 Thunder Tiger marine engine with muffler and a pull start. Good for learning how to drive.
RE: parts wanted
hello again just got home my grandsons and i thank you for your help in fact some time this week we are taking jamils boat on its maiden voyage wish us luck. now to business yes iam intrested in the mounts and the engine tell me what its going to cost me with shipping and we will work pyment arrangements.hope to hear from u soon.
RE: parts wanted
hello my grandsons and i thank you for your help believe me its greatly appreciated. just want to mention THAT JAMIL MY SECOND YOUNGEST GRANSON AND I are taking his boat out on its maiden voyage some time this week wish us luck. again thanks.
RE: parts wanted
Here is a small .12-18 size hull. I will not be using. Trim tabs cowl locks radio box turn fins ,driveline.
the rudder on the table is the one for that size hull. the one on the hull is a .45 size rudder.
The hull is a HOR
http://www.horracing.com/product_inf...roducts_id=101
The hull is a HOR
RE: parts wanted
hello neil again thanks. i may have someone intrested in the hull as u described it box, t/t ,stinger. the strut and rudder that you described for 20 a piece can you do better on the price.
RE: parts wanted
That rudder can be had here. http://kintecracing.com/Hardware.html
It's a FE site but some of the stuff can go nitro
