3.5CC MRP TUNNEL HULL
HI IM NEEDING GOOD INFO ON WHERE THE BOAT SHOULD BAL. FROM FRONT TO REAR ALSO WHEN BOAT IS UP ON PLANE HOW MUCH OF THE PROP SHOULD BE BREAKING THE SURFACE OF THE WATER. PLEASE ONLY REPLY IF YOU KNOW FOR SURE. I HAVE HAD ABOUT 10 DIFFERENT ANSWERS ALREADY AND NONE OF THEM MATCH. THE BOAT IS RUNNING FAST BUT NOT MUCH OF A ROSSTER TAIL AND I CAN TELL ITS NOT BAL. RIGHT HELLLLLLLLPLEASE THANKS -SID 417-235-8304 7 DAYS A WEEK 24 HRS. A DAY
RE: 3.5CC MRP TUNNEL HULL
Outboards don't make the big roostertails like monos do. I had one of these hulls, actually 2 of them, one was the electric version. The CG should be at about 28% forward of the transom. Set the motor up so that the center line of the prop shaft at the drive dog is slightly above the bottom of the sponsons. Tweak from there.
