Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
OS .21 xm prop shaft lube
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 04-29-2013, 08:58 AM
2916jr
Default OS .21 xm prop shaft lube
I just bought a top speed 2 with an os .21 xm outboard on it and after searching forums I can't come to a conclusion on how to do this. Some say grease it others say oil it? I am new to these outboard engines and would like to know the proper way it needs to be done.
Eric
Old 04-29-2013, 11:11 AM
Tombsy
Tombsy's Avatar
Default RE: OS .21 xm prop shaft lube
I grease the flex cable after a days running with blue marine grease but I also run an "oiler", a small container such as a large fuel filter that feeds oil while it's running.
Old 05-01-2013, 09:13 AM
advanced builder
advanced builder's Avatar
grease -your choice in brand. I like a water-resistance grease like Evenrude grease. If the shaft /bushing is well worn oils will seep out just setting. Some change the grease fitting for a oil fitting and vice versa
Old 05-01-2013, 01:35 PM
Tombsy
Tombsy's Avatar
An oiler only supplements the grease while it's running. Here's a pic of the setup on my VS1 that won District 16 last year.
