Newbie and his new prop!
Well, i finally got my new prop and prop nut installed and tested it today and i'm happy with the results!! It gets on plane faster and carries it's speed through and out of turns to the top end better than it did with the old prop. The prop is billet machined aluminum and is 37MM in diameter with a 1.4 pitch.
RE: Newbie and his new prop!
Also, i'll finally burn the last tank tomorrow of the 33% traxxas fuel the boat came with when i got it. I know traxxas fuel isn't the best.
What do you guys that run a .18 nitro motor run for fuel? I'm wanting to stay with at least a 30% nitro content. I'm also running an O.S. #7 plug.
ORIGINAL: Jerry Dunlap
It is not uncommon to run 50% nitro fuel in .18 size marine engines.
JD
JD
50% isn't that high when you consider that some use 70% in their .21 and smaller engines to squeeze every last ounce of power out of them. I run 50% in all my boats since it's plenty powerful. Something you also need to remember is that as you go higher in nitro, the MPG goes down. While nitro is an oxidant that helps give more power, the alcohol is actually the fuel. As you increase nitro, you need to increase tank size to make sure you have enough fuel to finish your heats if you're racing
ORIGINAL: Hydro Junkie
O'Donnell or GrimRacer fuels are two brands that are easy to get and are both good.
What scares me in that picture is the streamlined prop nut. They're not known for staying on very well.
BTW, that appears to be a flex cable setup on your hydro. You may want to consider leaving a 3/16" gap between the drive dog and the stuffing tube.
ORIGINAL: Ron Olson
Also, the last time i had the motor out, i pulled the drive line to inspect it and found that it doesn't have a flex cable setup like most others i've researched. It's a direct drive setup with a solid shaft.
[quote]ORIGINAL: Ron Olson
[/quote€
Oh, the brand of my boat is a Vantex and it's 700MM in length with a Vertex .18 motor and the shaft is 4MM.
I take it that boat is one of the Pro Boat Bud hulls, just looking at the picture of the transom
The first stainless steel prop i order was from Horizion Hobby and an upgrade for the Pro Boat 1/12th scale Miss Budwiser, but once i received it the shaft bore was too small for my setup so i bored it out to fit and installed the prop. It was to small in diameter and the boat barely moved. I believe this Hydro is a little bigger than the 1/12th scale Pro Boat Miss Budwiser.
I put my old Ofna buggy radio system in it, a sullivan tiger drive and an air fiter to keep from getting water in the motor as it splashes through the hole the cowling. It's been working great me so far.
http://www.fuyuanrc.com/detail.asp?id=14074
Okay, it's a Pro Boat knock off. It's based on the 1/12 Bud hull but has just enough "tweaking" to make it sellable without running into legal issues
So are you telling me I got a lemon on my hands? Lol! Either way it's still fun and besides, I only paid 40 bucks for it.
That's the speed i estimated i've been getting from it the couple of times i've had it on the water. Somewhere between 30 & 40MPH. Which is good enough for me, i'm not looking to start racing with it.
FL
I had one of those not exactly the same paint scheme but very close. The Hull is the same dimensions as the Bud\Pro Boat but Heavier built\laid up and will take a bit more abuse but less top speed due to weight. The biggest issue is the Exhaust System. MACS sells a Wrap to Center header that will fit (designed for the Pro Boat) but will need to be cut down as close to the last bend as possible while leaving enough to get a coupler on, and a MACS 2.5 Pipe Cut down to work best for your APP. (test then Trim and Test Again) will give you quite a bit more Top End. Other than that and the CY\Vortex Engine most of the other aspects of the set up are superior to the Pro Boat.
ORIGINAL: amax
I recently put a pro boat brand high performance turn fin on and tested it yesterday. I have to say it helped, cause it really cuts a right hand turn sharper and flatter than it did before.
About the exhaust, i've looked at the MAC setups, but recently found this on ebay, what do you think about it?
FL
a 40mm prop is WAY To Much for the CY\Vortex .18 a 35mm to 36mm is much more suitable. the Octura M435\3 is my prop of choice on a Stock Engine but the Y535 (2 blade) is also a popular choice. You want a prop that will let the engine turn up into the High RPM Range easily because these small displacement engines don't have a lot of torque to turn big dia. or high pitch props.
Also Never use an Unbalanced or Unsharpened Prop it will rattle the drive train apart and leave your drive shaft and prop at the bottom of the pond. Not to mention the performance it's Robbing you of.
That exhaust system SUCKS.
You don't want any more connections than absolutely necessary, each Connection is a disruption in flow and a potential Leak when the coupler burns out. Also having a coupler That Close to the exhaust port is a very bad idea when you get the fuel mixture dialed in the heat\Fire will eat that coupler in a matter of minutes.
Header Length is a Critical part of Tuning as well as Pipe Length Longer is Higher Torque\Lower RPM's shorter is Higher RPM's\Lower Torque, and Each Boat\Set Up\Driving Style is different. Even with the MACS Wrap to Center(WTC) Header it difficult to get the header short enough to achieve the RPM range the .18 engines are capable of. I had to Cut and Modify the MACS WTC header so it came Up and back then angled the pipe across so the tip of the pipe ended at the rear center of the hull to get it short enough to reach the range I wanted. BUT I'm a Speed Junky.
Thanks for the tips amax!
I'll also just save up and buy the MACS WTC header and 2.5 pipe and play with it a little and see how it does.
Yes look for a different pipe. http://www3.towerhobbies.com/cgi-bin...?&I=LXZ557&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXZ660&P=0
amax, when you put the wrap to center header on your old vertex .18, did it clear the high speed needle without having to rotate the carb?
ORIGINAL: advanced builder
Scratch that last question advanced builder.
I pulled the threaded pressure fitting out of my old 1/8th scale buggy fuel tank. It's 1/8th inch in diameter, when i get the MACS pipe i'll drill an 1/8th inch hole just before the fattest part of the pipe and put some high temp RTV silicone on the threads of the fitting to ensure a good seal when i install it.
