K&B Exhaust throttle
I have a 3.5 K&B in a Seaducer 20 mono hull. It has the exhaust throttle that I'm done screwing around with. The boats only being used for weekend messing around. Can I put a carb on this and do away with the exhaust throttle. If so what carb can I use. I have a red 7.5 carb. Is that to big? Any help would be great. Thanks Ken
Ron it has a crankcase pressure fitting. Should I use that for pressure still? Or block it off and use a fitting on the pipe? Also Where is the best place for an outboard 3.5 k&b pipe??
