Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
os .90 marine engine cooling questions
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 08-28-2014, 10:42 PM
madmax421
Default os .90 marine engine cooling questions
So i picked up a pristine prather piranha with an os .90 marine engine. I saw this as a huge score , and am readying it for the lake house this weekend. My question about the motor is, the 90 has a double cooling jacket. I dont feel the flow from the rudder pick up is enough water volume for this engine. I am adding a second water pick up and this one is a larger diameter. Should i feed the head or the sleeve/casing jacket the higher volume water line?
Old 08-30-2014, 06:21 PM
Ron Olson
Ron Olson's Avatar
You'll find out soon enough why you scored the OS .90 so cheap as you're going to spend a lot of money on fuel! The good thing is that they run well on low percentage nitro, 40% max.
Where to add the 2nd line hook-up is a good question. Myself, I'd run it to the sleeve but you may prefer it the other way around.
Old 09-01-2014, 07:28 PM
madmax421
I ended up running the higher volume water line to the head. Higher temps,more water.
Old 09-02-2014, 12:48 PM
Hydro Junkie
Hydro Junkie's Avatar
Maybe, maybe not. Overcooling can adversely affect how the motor runs as much as overheating can. You might want to consider putting the larger line on the exhaust instead
