Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Hi anyone know where i can get
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 11-16-2014, 10:47 AM
duty
Default Hi anyone know where i can get
a high speed needle for axel/rossi .60 marine ??
Old 11-18-2014, 04:53 PM
advanced builder
advanced builder's Avatar
Have you looked at Tower Hobby
Old 11-18-2014, 06:29 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Maybe e-mail Axe Rossi through their website since the part may not be in their online catalog. http://www.rossienginesusa.us
Old 11-18-2014, 07:47 PM
advanced builder
We're did you find part #52 in the catalogue lol have fun. Cap off the HS needle opening and go inline with this http://www3.towerhobbies.com/cgi-bin...&I=LXCR66&P=0#
Old 11-19-2014, 01:55 AM
1QwkSport2.5r
Eww... OS parts for a Rossi? Blech.
Old 11-19-2014, 03:24 AM
duty
thanx
Old 11-19-2014, 03:25 AM
duty
part #52 ? why would I go with inline ? and do that ? im kinda new to this ....
Old 11-19-2014, 03:26 AM
duty
Originally Posted by 1qwksport2.5r View Post
eww... Os parts for a rossi? Blech.
im taking you dont like this idea ?
Old 11-19-2014, 07:16 AM
advanced builder
That OS needle is the most widely used needle in RC boating. I run that needle on my .21-.45-.67CMB. Your local hardware store has mm tread set screws to cap off that end. Put 1-3" of fuel line between needle and fuel nipple on your carb. All good. A new CMB comes with a needle I prefer a OS needle. Remote needle which end to nipple both ways will work.
Old 11-19-2014, 07:19 AM
advanced builder
The engine doesn't know how to read. LOL
Old 11-19-2014, 07:23 AM
duty
that os needle is the most widely used needle in rc boating. I run that needle on my .21-.45-.67cmb. Your local hardware store has mm tread set screws to cap off that end. Put 1-3" of fuel line between needle and fuel nipple on your carb. All good. A new cmb comes with a needle i prefer a os needle. Remote needle which end to nipple both ways will work.
wow thank you for the info !!! Curious you wrote you prefer the os needle why ?
Old 11-19-2014, 07:31 AM
advanced builder
Top or bottom needle is also used. The middle 1 is made out of plastic
http://www.mecoa.com/acc/needles/remote.htm
Old 11-19-2014, 07:33 AM
advanced builder
.experience
Old 11-19-2014, 07:36 AM
advanced builder
Pipe length is around 12 1/2" from center of glow plug to wide spot on pipe. What pipe you use?
Old 11-19-2014, 07:48 AM
1QwkSport2.5r
I don't like OS anything. If I were to use a remote needle valve, I'd use one from Jett Engineering before any other. But before I resorted to that, I'd try to find the needle valve that fits the engine the way it came from the factory. If the company is still in business making engines and parts, I'll contact them first before doing anything else. I'm kind of a jerk like that.
Old 11-19-2014, 07:53 AM
advanced builder
Have you ordered from Italy lately- have fun.Why does 1 replace a stock carb for a racing carb?
Old 11-21-2014, 03:48 AM
duty
http://www.mecoa.com/parts/985/985-003.jpg?id=2160 THIS IS THE ONE I ORDERED ..
Old 11-21-2014, 07:29 AM
advanced builder
A good Choice. The idle needle can be cut off flush with inside dia of the carb . If you want . After you screw it in till it stops then then look inside mark it then remove the idle needle and cut off at your mark. Many do that. Some don't. Recheck all by putting your fingers at both ends of your carb and blow into your fuel line. CKing for air leaks if found reseal where you find the air. Leak. A good starting spot is 3 1/2 turns out . You don't want a high rev at the table. If she revs high turn needle out. And restart if you keep the small idle screw turn out about the thickness of a Popsicle stick. Turn in if reving high
Old 11-21-2014, 09:20 AM
duty
a good choice. The idle needle can be cut off flush with inside dia of the carb . If you want . After you screw it in till it stops then then look inside mark it then remove the idle needle and cut off at your mark. Many do that. Some don't. Recheck all by putting your fingers at both ends of your carb and blow into your fuel line. Cking for air leaks if found reseal where you find the air. Leak. A good starting spot is 3 1/2 turns out . You don't want a high rev at the table. If she revs high turn needle out. And restart if you keep the small idle screw turn out about the thickness of a popsicle stick. Turn in if reving high
dam i guess now i know why you have 3,049 posts !!! Well im waiting for it to arrive now so we shall see ...
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
