Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
JAE 21 Nitro Outrigger
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 10-04-2015, 12:24 AM
Extra Fury
Default JAE 21 Nitro Outrigger
Hi.
I have purchased a hardly run JAE 21 Nitro Outrigger with a Novarossi TOP Race T 21 M inboard Nitro engine, with Novarossi supplied tuned pipe.
It all needed a real good clean up.
Size 31" x 22.5"
4 issues I need some advice with:
  • No prop with it. So, what make, diameter/size, pitch prop would best suit this hull and motor for max speed? (Code No #). I can work the prop over / sharpen, etc.
  • What would be the max engine for this rig? Make, size? Prop.
  • What % fuel ?
  • What plug?
Grahame
Old 10-12-2015, 10:04 PM
geraghty
geraghty's Avatar
Prop= ABC H-5
Leave it as a .21...you will be happier...
30% to 55%
McCoy MC-9 or MC-59..... Rossi R-6......
Old 10-13-2015, 01:06 AM
Hydro Junkie
Hydro Junkie's Avatar
Grahame, you have one of the masters of setting up boats giving advice, I would follow it to the letter
Old 10-14-2015, 06:11 PM
Ron Olson
Ron Olson's Avatar
If you look in the instruction manual at the front, you'll see Rod's name there as he's part of the JAE team.
Get that NR dialed in and you'll have plenty of motor for that boat. Just take a change of underwear with you to the lake!
Old 10-15-2015, 07:10 AM
Hydro Junkie
It's not that bad, Ron. That is unless one of us drives his boat
Old 10-15-2015, 10:21 AM
Ron Olson
Ron Olson's Avatar
I had one Marc. I've built 2 of the .12's also and still have one of those.
I missed seeing Rod at Hobart this year. I didn't stay but only about 4-1/2 hours there as the weather was so crappy on that Saturday that I rolled down there. He sometimes brings a HUGE bag of Halloween candy with him to hand out to the kids that come down to watch.
They're good kits. A lot of the racers are running them now in both the .21 and .21 classes. Usually most of the JAE team shows up at Hobart. Truex is too busy running his NASCAR Cup car that weekend.
Here's a couple of David Hall's boats then Joe Petro, Mike Walker and David Hall.
Name:	Hobart 2015 022.JPG
ID:	2125485   Click image for larger version
Name:	Hobart 2015 029.JPG
