Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
thunder tiger Pro21R carb needed #9249N
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 01-26-2017, 04:12 PM
boydog40
Default thunder tiger Pro21R carb needed #9249N
any idea where I can get one??? I have scoured the internet with zero luck
thanks
Old 01-26-2017, 07:20 PM
Pond Skipper
Pond Skipper's Avatar
You can use another brand carb and press on having fun.
Old 01-26-2017, 07:29 PM
boydog40
it has a "SH engines" carb on it now, that has the linkage on the throttle moves in and out instead of rotates fwd and backward.
never seen one that has done that so I don't know how to connect it to the servo.
any help there will be appreciated
Old 01-31-2017, 06:57 PM
crapshooter
you can use a Dubro Bell Crank which is an L shaped Nylon part that is mounted via its center hole and you just use a ball link at the carby end and pushrod piece to attatch to bell crank then another pushrod that will go from the other side of bell crank to the throttle servo. sorry can,t post a pick .
Old 01-31-2017, 07:08 PM
boydog40
can you draw me a picture of it!?
boydog40
this is a slide carb not a rotary
Old 01-31-2017, 08:41 PM
crapshooter
yes i know its a slide carby thats why you need the BellCrank to act as a lever so one end pulls the carby barrel and the other end of bellcrank pushes. just visualize an L shaped piece of plastic , one end to carby barrel and the other end to throttle servo, both with links at each ends and pushrods to do the push and pulling.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
