Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Miss Vegas..larger flex shaft??
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 03-13-2017, 05:05 AM
Captainron2181
Default Miss Vegas..larger flex shaft??
I want to put a larger flex shaft in my miss Vegas with out changing the tube. I see a few guys have done it,do you still run a liner or remove it? The stock shaft is .150 and its a 1/4 inch tube. Any help would be much appreciated.
Old 03-13-2017, 11:33 AM
Pond Skipper
Pond Skipper's Avatar
You need some Teflon no way around it really don't want to go metal to metal the
strands could start breaking.
Old 03-13-2017, 12:33 PM
Captainron2181
Thanks for the input...
Old 03-13-2017, 12:47 PM
Captainron2181
Sorry that reply was so short,I just joined this site and that was my 3rd attempt to a reply...lol! I was hoping some one that has done this may reply....thank you for your help Pond Skipper.
Old 03-13-2017, 06:46 PM
Hydro Junkie
Hydro Junkie's Avatar
Interesting you should say that. I've got two scales that have never had teflon in them and I know for a fact that one has been raced since 2001 with the same flex cable. My remanufactured Dumas Pak doesn't have teflon in the tube and it hasn't been a problem either. As long as the bends in the tube are gradual, rather than fairly abrupt, a good coat of grease on the cable will do as much as teflon will
Old 03-13-2017, 08:57 PM
crapshooter
yes i have never used teflon tube liners in any of my ex glow boats and current gas boats , no problems whatsoever. Teflon can burn and cause binding issues.
Old 03-14-2017, 12:11 AM
Captainron2181
Thanks guys! That is good to know,I wasn't sure if I could run with out the liner. That will make this much easier!!
Old 03-14-2017, 01:45 AM
crapshooter
bare in mind if your going to use a larger diameter shaft just make sure theres enough space between the shaft and inner tube for oil or grease to run freely. if its too tight a fit things will get rather warm.
Old 03-14-2017, 01:56 AM
Captainron2181
Roger that! Shouldn't be a problem,the liner is pretty thick....thanks for the reply!
Old 03-14-2017, 11:15 AM
Ron Olson
Ron Olson's Avatar
You don't need the Teflon tube as I did away with those a long time ago. I've seen Teflon tubes melt, it ain't pretty when that happens. Just keep the cable well-greased.
OK, why do you need a larger cable? The stock engine only needs the .150" cable with the 3/16" propshaft.
Old 03-14-2017, 11:24 AM
Captainron2181
I'm putting a dynamite .32 in it.
Old 03-14-2017, 11:39 AM
Ron Olson
Ron Olson's Avatar
It's just a bad idea all-around putting a Dynamite .32 in a Miss Bud bull.
See this thread: http://www.rcuniverse.com/forum/spee...mar-hydro.html
Old 03-14-2017, 12:22 PM
Captainron2181
It's a miss Vegas....I've seen a few built and the run great..I don't expect to run it wide open I've just had real good luck with the dynamite engines. I shoehornd a big red in my revo truck and it runs great, over kill...yes sir! But I don't run it half as hard as the traxxas3.3...which was a tune ing night mare.I've had no luck with the super tiger engine...on my second ,thinking I got a bad one first time around...more of the same with the second. I've got a 200 black max on my 19 foot clam skiff once again over powered but that's what the throttle is for..lol!!
Old 03-14-2017, 12:28 PM
Captainron2181
[h=1]Dynamite .32 Miss Vegas[/h]
ka350kaptain 4,132 views. He's on YouTube...and this site.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
