Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
name of tool ??
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
name of tool ??
Old 09-29-2003, 07:07 PM
550racer
550racer's Avatar
Default name of tool ??
whats the name of the tool that u can use to pinch the fuel line an it clicks on to hold it pinched it looks like a operation room tool? help me out i wana go pick one up tomrow where can i find them at? hardwear store?
Old 09-29-2003, 09:02 PM
I_C_E_Y
Default RE: name of tool ??
Fingers
Old 09-29-2003, 09:17 PM
Lee Belew
They are called hemostats. You can buy them at most tool places.
Good Luck
Lee
Old 09-29-2003, 09:33 PM
Ken Hildreth
If that is what you want to use, you can put fuel tubing over the ends and it will prevent it from damaging your fuel line. Ken
Old 09-29-2003, 10:28 PM
550racer
550racer's Avatar
yup thats what the guy at the namba guy used to get my boat runnin cuz it was floodin to much an that tool pinched the line to it dont flood till it starts thats the only problem i was havin but i like that tool i know u can use ur fingers or sumtin else but that tools nifty yeah ill put a paddin on it so it dont cut the line
Old 10-02-2003, 08:36 AM
75Blazer
Have you considered using spell check? [sm=biggrin.gif]
Old 10-02-2003, 06:00 PM
Ron Olson
Ron Olson's Avatar
You can use the hemostats also with the rubber antenna tips, clothes pins or IV regulators. www.grimracer.com has some shutoffs in there, part# 104 for $2.50 a pair. Look in the hardware section.
Old 10-02-2003, 06:22 PM
550racer
550racer's Avatar
them fuel shut offs look nice im might order a pair of them too i alredy have my hemostat comin in the mail. hey Ron when u fuel up ur gray thunder does the fuel alredy start to travel along the line to the carb? myne seams to be doing that and its flooding it somehow so that guy pinched it off with the hemo i thought thats what the primer pump is for? to pump it to the carb but myne goes without even pushin the primer
Old 10-03-2003, 03:23 PM
Ron Olson
Ron Olson's Avatar
I've got a Sullivan SS-4 tank mounted in mine so I no longer have the primer. I pull off the fuel line from the carb to fill it using an electric pump. There is fuel already in the line then so all I have to do is pull it over to start it.
Old 10-03-2003, 05:27 PM
550racer
550racer's Avatar
that brings up another question.. for the tank the guy told me to get a soft brass tube and bend it right in the front of the tank and not to use the klunk method.. how did u do urs? what kind of brass is it? like a number or brand?
also for the engine once its been leaned and set right it shouldnt flood no more when i first start it? and do u flood the engine to clean out the after run oil for the first time? then empty the flooded fuel an then start it?
Old 10-03-2003, 06:11 PM
Ron Olson
Ron Olson's Avatar
Carefully bend the brass trubing to go into the rear corner of the tank by the opening. Bend the other one up towards the vent at the top of the tank. It will take a while to get it right. cut off the excess tubing. Also, one more thing, Sullivan makes the tanks 2 ways, one harder than the other. The softer one is more transparent which makes plumbing it easier.
Old 10-03-2003, 06:52 PM
550racer
550racer's Avatar
what kind of brass? the ones that come with the kit are hard to bend the guy told me to get a soft brass thats easy to bend..i foregot what kind it was
Old 10-03-2003, 06:59 PM
Ron Olson
Ron Olson's Avatar
Yes, the brass that came with it unless you can get some softer. That's why my last response started with "Carefully".
Old 10-04-2003, 05:39 PM
polstery
Heat the brass up with a torch then let it cool and it will bend real easy. not red hot either just get it hot.
Old 10-04-2003, 08:38 PM
550racer
550racer's Avatar
i got it done .. i used the 4 oz flex tank from sillivan alot easer to see inside what im doing.. but now i need a way to put it in the boat
