Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
steps to startin nitro
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 10-01-2003, 06:41 PM
550racer
550racer's Avatar
Default steps to startin nitro
i think i got this right tell me if im wrong this is for starten the first time after it sittin for a few days u should only do this first time startin it for the day to clean out the after run oil an get fuel in there
1.fill tank half fuel watch for fuel in the line
2.pinch fuel line with hemostat after u see fuel in the line
3.put finger over carb and remove glo plug
4.pull start while fingers on the carb look for fuel shootin out of the top if so u have fuel flow
5.empty fuel out of the engine buy the exhost pipe
6.put glo plug in and take off hemostat
7.put glo starter on the glo plug and pull the pull start till it turns over hold open the carb a little when starting
Old 10-02-2003, 08:59 AM
Mr Cajun Gator
Default RE: steps to startin nitro
1/2 tank of fuel???? I fill mine to the top,
cleaning the after run oil from the engine yes.
pinch off fuel line, only if its set so rich that it floods the engine(after break in, you can set your needle to avoid this)
I'm useing a 12v starter so I put my plug in after cleaning out the oil, and I use the remote to close off the carb until the fuel gets to it, then release to start, then work the throttle a few time to clean the rich fuel out, then its in the water
Old 10-02-2003, 12:00 PM
550racer
550racer's Avatar
well i get it full after i clean out the after run oil
