Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Flywheels
Old 11-25-2003, 01:45 AM
pro27
Default Flywheels
I picked up an OS 12CV in a bunch of stuff the other day. I'd like to use it in a new project I have in mind. The only thing I need to make it complete is a flywheel.
Is there anywhere you can still get flywheels that might work?
It has a 10-32 shaft, so it needs a 3/16 hole for the shaft.
I was rummaging around in my Goldy Oldy stuff and found some Dumas flywheels that fit, though it looks small, but the weight feels about 2 oz.
Any suggestions?
Old 11-25-2003, 01:52 AM
torpedox
Default RE: Flywheels
[link=http://www.osengines.com]O.S. engines[/link]
the flywheel you have should work ok, you wont hurt anything by trying it.but you may want to contact os and see about any specs on the right one. Good luck.
Old 11-25-2003, 02:53 AM
pro27
ORIGINAL: torpedox
I thought of contacting OS, but my luck on mfg responses is non-existant. Thought someone here could advize. I'll probably try the one I have, but will also contact OS as you suggested.
Old 11-28-2003, 05:46 AM
Saugling
what about this one:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCB06
Old 11-28-2003, 09:11 AM
pro27
Suugling,
sometimes things just pass you by............I don't know how I ever missed this one.
Thanks alot for bringing it to my attention.
Old 12-10-2003, 08:55 PM
Ron Olson
Ron Olson's Avatar
The O.S. flywheel does the job. I have them on both of my .12 powered boats, my mono and outrigger hydro. Any other one made for any of the .12-.18 powered boats on the market will work also. They all use a 5mm shaft.
