Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
nitro hammer hop up Question???????????
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 02-22-2004, 12:08 AM
mburian02
Default nitro hammer hop up Question???????????
can anyone tell me is there are hop ups i can buy for the nitro hammer????? want to make it as fast as possible something like props or and thing of that sort??????? any info would be greatfully appreciated....
thanks in advance
mike
Old 02-22-2004, 05:56 PM
Ron Olson
Ron Olson's Avatar
Default RE: nitro hammer hop up Question???????????
OK Mike, I've helped some others out with this very question. I don't own one but have worked on a few.
You can upgrade the prop with an Octura X-435 or an X437 if you put a small piece of brass tubing between the prop and shaft to take up the slack. Cutting a 1" diameter hole over the carb in the cowling will allow some cool air to get into the carb instead of sucking the hot air in from the rear intakes. I think that the tuned pipe is too long and could use a serious shortening. If you want to spend the coin and don't mind doing some surgery, a surface drive could help to get more RPM and speed out of that puppy.
Read some of the other postings in this section.
Old 02-22-2004, 09:34 PM
mburian02
ok , i am very new to rc boats so my next question is where can i find the props you are talking about?????and about how much do they run???
thanks in advance
mike
Old 02-22-2004, 09:42 PM
Ron Olson
Ron Olson's Avatar
OK, I get this question a lot also. Most Hobby Shops can get them or else one online site that carries these sizes is http://www.finedesignrc.com/octuraprops.asp
Links? Yeah, I got links!
