Shockwave 36 Pics
My Feedback: (7)
FL
RE: Shockwave 36 Pics
I took the bottom screwout from the rudder cuz my rudder kept braking, make sure you lube the shaft well and put plenty fotationg insede the hull also i change the servo wire with a 440 as advied from other member, anything else I would like to put a scoop to draw more air inside
FL
We run dynamite 20% and in relation to the 4-40 its the push rod the original its weak so we replace it with a dubro push rod part # 360 I think.
CA
o ok i understand now so is there a website you can buy 20% blue thunder from because i want it by the gallon but i cannot find it ANYWHERE but the UK. i found the quarts at some sites.
Do a search in here or go back a page or two to find more info on the Shockwave 36.
Your Hobby shop should be able to provide you with some good fuel for this boat. You'll want to find some with 15-20% oil content and you should be able to run up to 40% nitro with no trouble.
CA
well when i read the manual for the engine it highly recommended the blue thunder which they make so is this true or are they just trying to advertise? so what is the best fuel i can get and im not doing anything that serious so 20-30 percent is fine for me.
IL
Most important is to stick with car/boat fuel. Do not use airplane fuel, it has too much oil in it. If you want some series power, get O'Donnell 50%, it makes a huge difference!
Have fun!
Have fun!
