'Wild Thing' Construction Pictures
#351
Hi all,
Did a little on the fit out today, just so I could wake everyone up, who might be following this thread......
Like they say Rome and the pyramids weren't built in a day....!!!!!
Still got more to do.....
Next update 6 months time.....
#353
Ron,
I measured the pipe length after cutting more off the header pipe and it is currently at 8.5 inches (220mm) from the glow plug to the widest point on the pipe.
Thats where you said earlier in this thread to start at.
The pipe will just clear the radio box. Will design a mount for it.
Can some one refresh me as to the balance point (%). Was it 32 to 34 %...????
#354
Nice work Ross. Slow and steady wins the race. I have models in my shop that have been on the back burner for years. You are moving like a rabbit compared to some of my projects. Once you get the WT in the water I'm sure you will be very pleased. I was with mine.
#355
Guys, will someone please kick me in the rear end. [sm=punching.gif]
I dont want to get the award for longest boat build in history.[:@]
Not much left to do, so why am I taking soooo looong????[
Oh thats right, I'm married................[:-][&o][:'(][sm=cry_smile.gif][sm=thumbs_down.gif]
#356
Looks like all the followers of this thread have moved on.........understandably.......
Any idea at what % of nitro and Oil, I should run in this ASP .21 engine...???
Here is the custom pipe clamp I made.
#359
Thanks Fastpepper,
The pipe I'm using is a CMB TT pipe.
The length of the hull is 780mm or about 31 inches.
#361
1 Post
ORIGINAL: Macleod
It's FINISHED...!!!!!
Mart
#363
Not wet yet, still got to check all the fastners and adjust the setup.
Pump some fuel into her and do a bench test fire.
And yes, it has been a while.......how long did the pyramids take to build......????
#364
KS
Thats ok perfection takes time
, and from what I see it sure looks good to me! Not a fan of using a volt watch BUT I have before [&:]
#365
ORIGINAL: Macleod
Thanks Fastpepper,
Thanks Fastpepper,
thanks
Justin
#366
Hi Justin,
I got the pipe (CMB .21 Silenced Nitro Marine Tuned Pipe) from here many years ago.
[link=http://www.hobbysupplies.com.au/CMB%20Pipes.htm]Hobby Supplies Australia[/link]
They still list it but don't know if they have any.
#367
In Canada, try http://www.hallammarinehobby.com/ for the CMB TT pipe. They're as quiet as a popcorn fart! [sm=lol.gif]
#370
Saw it with my own eyes.................................it has been run!!!
How did you guys go after I left, hang around for a while with it??
Johno
Johno
#372
Johno, after you left I ran it for a few tanks, total of about 750ml of fuel went through her.
After each run I checked her over. Adjusted the trim tabs a little which stopped the rocking.
Only ran at 3/4 throttle and on the rich side for her run in, plus setup is not right so I didnt have full throttle.
She started first time every time......no leaks in the radio box.
Will get the video up soon.
#373
Did you do some on-water testing of the radio box?
I don't know if this will help with setting up your throttle linkage or not but this is what I do, open the carb all the way. Turn on the TX and RX, hold the throttle wide open then shut off the RX then adjust everything. Hopefully when you turn the RX back on the throttle will close all the way or close to it and adjust the trim from there.
#374
Ron, I had the servo set right . The setup I meant by the the tuning, mixture, prop and pipe setup is not right as she would not give me full power when I gave her full throttle.
Sorry didn't mean to mislead.
Editing video now, so will be up soon.
