Quick Question on a K&B inboard...
MN
I have an old K&B .40 inboard and i need a glowplug. Can i use an 0.S. 8 in it or does it need to be a special glow plug. Just need a quick answer on this thanks...
RE: Quick Question on a K&B inboard...
Hii Friend!!!
Isintersting you using original glow plugs of K&b!!!!
If you using more than 20% of nitrous, You will necessery to put in your engine HP Glown Plug #7300!!!
But... if you using standart fuel(10% nitrous) Is possible you using 1L Glown Plug #7311
regards,
regards,
