air cooled engine in boat
what are the cons of putting an air cooled nitro car engine in a boat? would it overheat quickly? would you steer clear of doing so?
RE: air cooled engine in boat
It depends on which boat and which motor. I have several .12 powered boats that are running air-cooled car motors. My boats have a low enough profile on them so that getting air to the heads is no problem. I've even taken the top 3 fins off one motor because it cooled so well. The other good things in most boats is that we have cooler air and more air than a motor trapped inside of a Lexan body with a little hole in the windshield. As long as the motor isn't blocked from getting cool air, I see no problem.
i would be running something very similar to laserflyer, a .16 air cooled megatech in a 30" custom shallow vee boat with all traxxas components, thank you both for the info very helpful and reassuring seeing as i already bought the motor.
