Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Mod. 1/12 Miss Bud
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Mod. 1/12 Miss Bud
Old 03-10-2005, 07:03 PM
Hairtrigger
Default Mod. 1/12 Miss Bud
o s .15 air cooled
Old 03-12-2005, 09:17 AM
pilotrc2002
Banned
My Feedback: (15)
Default RE: Mod. 1/12 Miss Bud
what is the temp on the motor after a full run?
Old 03-14-2005, 11:35 PM
Hairtrigger
don't know the temp ,but after each run you can touch the head. I also opened up the back of top to let out headed heat.
Old 03-15-2005, 12:02 AM
Hairtrigger
These motors will get more air than one in a car with a body on it. I'm working on a 1/12 miss bud with a .21 it's just about ready. It is also a air cooled.
ID:	244165   Click image for larger version
Old 03-15-2005, 12:06 AM
ejp67
Those are some of the nicest looking boats I've seen. I really like the one with the .21. That thing should hall *****. Do you have any running pix of the black one??? Very nice mod jobs.
Old 03-15-2005, 12:07 AM
pilotrc2002
Banned
My Feedback: (15)
I am doing a Miss LLumar with a OS 21
what size prop and flex shaft are you putting in yours
I have a Another Miss LLumar that is strait out of the box and it is okay just need more speed
can you send me pics of the drive system in your 21 size miss bud
Old 03-15-2005, 12:32 AM
ejp67
How fast is the .15???? I just bought one with a .18 air cooled in it.
Old 03-15-2005, 12:36 AM
pilotrc2002
Banned
My Feedback: (15)
my Miss Llumar will do about 30 on clean water but I did change the prop to a octura y535 and I am running 20% nitro
Old 03-15-2005, 12:42 AM
pilotrc2002
Banned
My Feedback: (15)
here are some pics of the Miss Llumar 21 convertion
it has a new 1/4 brass tube with a 3/16x21 flex cable with 3/16x3-1/8 stub shaft
the prop it a B-220 Prather Hi Performance propyou can see the differance in pro size
ID:	244180   Click image for larger version
ID:	244181   Click image for larger version
ID:	244182   Click image for larger version
Old 03-15-2005, 12:49 AM
Hairtrigger
sorry guys but for some reason I can't upload any pic . I will try again or will post tomorrow night. On the .15 is lighter than the .18 with about the h.p. I do have pic of the black boat and will post sone There are all air !!!!
Old 03-15-2005, 01:03 AM
Hairtrigger
The new prop is a M435 from Octura
Old 03-15-2005, 01:15 AM
Hairtrigger
this is the .21 drive all from octura ,flex drive and stut. making turn fin it will be the same as on the black boat.
Old 03-15-2005, 01:20 AM
pilotrc2002
Banned
My Feedback: (15)
I made my turn fin out of a old puddy knife I made Mine about 1 inch longer and 1/2 inch wider
Old 03-15-2005, 01:46 AM
Hairtrigger
I,ll send close up pic later of my turn fin. Here is pic of my racing boats, Hope you enjoy. if you are every in the Mobile,Al. area let me know by email at [email protected] I have a lake in back yard and I'm allways looking for someone who wants to race. Race what you broung[8D]
ID:	244196   Click image for larger version
Old 03-15-2005, 11:53 PM
ejp67
The mods on your red miss bud look awsome. That is one of the cleanest setups with a .21 in a miss bud. You truly can build some beautiful boats. I can't wait to try out mine.
Old 03-17-2005, 12:31 AM
raptorman60
[8D]I need to know are you gel coating these boats or what? These are the nicest finishes I seen! Please let me know.
YOUR BOATS ROCK
Old 03-17-2005, 07:40 AM
Hairtrigger
No there are a painted finish. I used dupont car paint, base coat, clear coat. Wet sanded between each coat with 1500 grit paper. The V hull is gel coat .
Old 03-17-2005, 05:19 PM
teamchrome
teamchrome's Avatar
Is there any other form of starting the Miss Bud other than the pull start? such as Tiger drive or Roto start?
Old 03-17-2005, 08:49 PM
Hairtrigger
Yes you can start with a belt it's a 17" one, you can also use the same drive start that is used on cars. there is a V groove in the flywheel already for belt start. If you every change motors buy one with out pull start it is a faster motor, also get one with a slide crab, it will repond a lot better than barrel type
Old 03-17-2005, 09:33 PM
pilotrc2002
Banned
My Feedback: (15)
I am putting a OS 21 RG in my Miss Llumar do you have pics that show more detail on how you instaled your 21(Motor mount, Place ment stuff like that)
thanks
ID:	245445   Click image for larger version
Old 03-17-2005, 09:41 PM
pilotrc2002
Banned
My Feedback: (15)
I need to work on my spelling......LOL
Old 03-17-2005, 10:00 PM
Hairtrigger
I made mine out of 1/4 alum. with slotted holes to fit in same holes on wood mounts that came in boat. I will send close up pic. Fri. of the mount it realy work well, I can move motor back and forth to change the CG if I need to. IF you was looking from a top veiw it looks just like the one that came in boat, but the motor mounts holes are slotted.
Old 03-17-2005, 10:05 PM
pilotrc2002
Banned
My Feedback: (15)
the Miss Llumar is done a little different
If you look at the pics above you can see the motor mount
Old 03-17-2005, 10:18 PM
Hairtrigger
Sorry I will take more detailed pic fri. and send a closer look at how i set mine up. but keep in mind that you can't tell from pic's but radio box has been moved back to clear flywheel and collet also the CG of boat.This motor should turn in the 30, rpm range
Old 03-17-2005, 11:14 PM
pilotrc2002
Banned
My Feedback: (15)
so do you feel If I move the motor about 1/2 inch forward it will hurt the CG?
I am putting a small 1 once feeder tank behind the motor or do you think that is not needed
