Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
just a thought
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
just a thought
Old 03-20-2005, 12:14 AM
eas___1990
Default just a thought
Ok was runnin my boat a bit yesterday and i wanted a bit more speed so i have been lookin at engines and thought about buggy engines.My first question is could i put one in the nitro hammer or not,second could i put this one in.It is the O.S. .18 cv-rx
Old 03-20-2005, 12:19 AM
Ron Olson
Ron Olson's Avatar
Default RE: just a thought
You can as it should be a bolt-in but I'd worry if the heat sink would get enough air. You'd have to run the boat without the cowling on.
Old 03-20-2005, 12:34 AM
eas___1990
Cowling?? the top,I was just thinking about cutting a section in it so it would get the air for that and for the power.Also if i do this should i change my prop or will it be alright???
Old 03-20-2005, 12:39 AM
Ron Olson
Ron Olson's Avatar
The OS does have more HP and RPM so it should be able to turn a bigger prop.
Old 03-20-2005, 12:45 AM
eas___1990
kool the only thing i would have to change if i get a bigger prop is the prop shaft.I might do this after this school year cuase i will be loaded from different things...How much speed do you think i would gain? jus an estimate
Old 03-20-2005, 12:49 AM
ejp67
I would say enough so that you wish you had a surface drive. The boat will probably pick up out of the water when you gun it.
Old 03-20-2005, 12:52 AM
eas___1990
yeah that would be sumtin.Surface drive was a though which i will prolly do later on after i get a job this summer.Since i have a little expierence with fiberglassin it should be to hard...I think i might jus do this
Ron Olson
Ron Olson's Avatar
I couldn't give you any speed numbers but it looks like a real powerhouse. Their latest .18 is a real killer though, 42,000 RPM with 20% nitro and using a .12 pipe. This was dyno'ed by a magazine reviewer. The only downside was that the threaded shaft is too short for us boaters to use.
Old 03-20-2005, 12:59 AM
eas___1990
the tz or tx? they both look really nice the reason for this one is price at only 99.99 its right in my price range lol jus under 100 dollars
Old 03-20-2005, 01:01 AM
ejp67
Well, if you do that and a .18 let us know how it runs. You would almost be better off buying a faster boat for what you are going to have in you NH. Gues how I know this. What am I talking about.[] I just bought a Miss Bud with a .18 in it.
Old 03-20-2005, 01:03 AM
ejp67
Heres another engine. This is the one in my new Miss Bud.
http://hobbypeople.net/gallery/146002.asp
Old 03-20-2005, 10:26 AM
Ron Olson
Ron Olson's Avatar
EJP, I have one of those motors sitting in my basement in pieces from my sons X-Cellerator. They are fast in his truck but when he had problems with the motor, I tore it down and found the piston falling apart! The skirting is really thin especially at the bottom.
Old 03-20-2005, 10:44 AM
eas___1990
when i have to replace parts i get the part from os and have the hobby shop guy install it like my con rod,it was like 24 bucks but well worth the money i have had no prblems with it yet.I was thinking about the miss bud or buying a shockwave 36 but jus decided to prolly go with this mod.Did you put the engine in brand new or jus buy the whole thing together?
Old 03-20-2005, 10:50 AM
Ron Olson
Ron Olson's Avatar
We bought it RTR.
Old 03-20-2005, 01:08 PM
eas___1990
stock stuff always seems to go heywire sumtimes for me[].I was wandering bout the water cooling system whether i would jus put a coupler in the two hoses or to take it out all together.Another thing would this affect the boats stability or not.
btw-does anyone know the rpm range of the stock nitro hammers .15?
Old 03-20-2005, 01:14 PM
eas___1990
i was just thinking could i just put the water cooling head on the .18 since it says in the description of it it is in a .15 crank case although it is a .18. The only other thing i could think of that would stop me from puttin it on other than its size is where the screw hole were drilled and taped.
Old 03-20-2005, 01:39 PM
TERBObob
My Feedback: (21)
TERBObob's Avatar
if the bolt holes do NOT match up , then you might try a KOOL KLAMP , they do work . Or , do as Ron said , make sure the cooling fins get PLENTY of air flow . I popped a buggy engine in a little ABS hull and she rips . ( well , maybe not rips , but does run well )
Old 03-20-2005, 03:12 PM
ejp67
For the cooling check this out. I don't know how affective it is but I'll find out once I get the boat
ID:	246523   Click image for larger version
Old 03-20-2005, 03:31 PM
TERBObob
My Feedback: (21)
TERBObob's Avatar
You can try it , but there doesn't seem to be enough contact ( cooling tubes ) touching the finned area .[&o] Make sure you do the "spit" test after running her a couple of minutes , otherwise , you might not have motor left .[&o]
Old 03-20-2005, 04:06 PM
ejp67
It is in a miss bud so there is plenty of cooling from the scoop anyway.
Old 03-20-2005, 04:38 PM
eas___1990
lookin pretty hot there ejp i am pretty shure i am gonna buy the engine this summer or close to summer if i can wait that long.
Old 03-20-2005, 05:19 PM
ejp67
NICE. I want to see how well it performs.
Old 03-20-2005, 05:54 PM
eas___1990
well i think i might buy it pretty soone here,I dont know who desinged the stock .15 but they did have the idea of easy starting aftera year of use in mind lol.I have been workin on the engine ALL day[:@] and just got it back together and stil a mother to start.
My conclusion is sell it for bout 35 or 40 or sumtin and buy that os buggy engine within a week or sumtin. or i could buy a .21[>:] what you guys think?
Old 03-20-2005, 06:08 PM
ejp67
A .21 wouldnt fit the mount and it would be too much for the little boat. I would probaly go with a .18 marine engine myself.
Old 03-20-2005, 06:10 PM
eas___1990
kool i will jus go with the .18 buggy engine then.[8D] i will prolly get sumtime soon
