Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
 Proboat Miss Budweiser 1/12 – Awesome! >
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 03-26-2007, 08:30 PM
  #251
Default RE: Proboat Miss Budweiser 1/12 – Awesome!
you guys (and girls) are legends on the quick replies. thanks.
How in the heck do you get to that low speed needle? the manifold is right on top of it.
My manual for the dynamite suggests 3 1/2?
Old 03-26-2007, 08:36 PM
  #252
misshydro's Avatar
It's on the header side of the motor it's on the linkage.there a regular head screw on the side of it. Turn the high speed screw first before the low speed screw.[8D]
Old 03-26-2007, 08:55 PM
  #253
yeah right under the exhaust manifold right? a little tight down there.
how difficult would a swap be? stupid question maybe.
Old 03-26-2007, 09:02 PM
  #254
misshydro's Avatar
To put the vegas motor in? supper easy!! No mods eather.your header and linkage and motor and coupler and motor mounts will bolt right up[8D]
Old 03-26-2007, 09:04 PM
  #255
My Feedback: (12)
piper_chuck's Avatar
ORIGINAL: JAY FORTAY
You must have a different carb, go with what the manual says.
Old 03-26-2007, 09:13 PM
  #256
misshydro's Avatar
No Chuck.I have a.15 and the aquacraft.18 now in front of me.Theres a screw on top of the carb with a spring under it. Jay the low speed screw is on the side of the carb were your throtel linkage goes too.
Old 03-26-2007, 09:17 PM
  #257
My Feedback: (12)
ORIGINAL: misshydro
No what? I was telling him to follow the manual suggestion for the high speed needle setting.
Old 03-26-2007, 09:25 PM
  #258
misshydro's Avatar
Sorry Chuck I'd thought he was talking about the top screw.But You and I'd said the low speed screw is on the side were the throtel linkage is at.[8D]
Old 03-27-2007, 04:03 PM
  #259
I AM CONVINCED THAT THIS DYNAMITE .15 IS AN ABSOLUTE PEICE OF JUNK.
I went to the shop to buy a bunch more stuff today to hopefully keep me happy out at the lake (i.e. plugs, after-run oil, grease, another 7.2v for the starter). i went to start the thing, and i couldn't even get it to turn. the piston is caught right in the middle of the stroke. I thought it was hydro locked so I did the normal procedure. I got it to turn while it was upside down (strong knocking noise, I then righted it, replaced the plug, and tryed to start it. It would not turn for the life of me. I feel like I am abusing the hell out of the thing just trying to get it started. I tryed to get it to turn with the plug out and upside down again to no avail... no go. This is starting to make me feel like I should have never tryed to get back into this hobby again, or should have gone electric. I know I should not feel this way though, so I will try to persevere.
Is something seriously wrong in there?
Old 03-27-2007, 04:38 PM
  #260
misshydro's Avatar
Well Jay it sounds like you chucked the con rod!! This is why I hate and call the.15 dynamite a piece of junk!!
Old 03-27-2007, 05:02 PM
  #261
so time for that little $84.00 investment we talked about? I am supposed to go to hobby town to show it to the owner tomorrow. Or would it be best to try to warranty it through horizon? can I use my tiger drive system on the O.S. motor. You are awesome on the quick reply, by the way. do you have the site page you when one of your subscribed threads is replied to or something?
Old 03-27-2007, 06:01 PM
  #262
misshydro's Avatar
Get horizon to fix it,since you have a warrenty on it. if I was you I would sell it and get the vegas aquacraft.18 motor![8D]
Old 03-27-2007, 06:48 PM
  #263
Sean Bowf's Avatar
If it is under warranty...I would get it fixed even if you never plan to use the motor again. You could always Ebay it to recoup some of the cost of the .18.
Sean
Old 03-27-2007, 08:23 PM
  #264
good call by all I will try to persue that avenue tommorow. Thank you for all of the help. i really appreciate it
Old 03-27-2007, 08:30 PM
  #265
misshydro's Avatar
You might get 50 dollars for it on ebay.That what they go for/get out of them.
Old 03-28-2007, 02:14 AM
  #266
Drmeff's Avatar
good call,
hey how long is the warrenty on those engines? My pullstart just kicked the bucked on mine... don't really feel like putting another one on there since I dont use my llumar much anymore...
Old 03-28-2007, 08:05 AM
  #267
Massey's Avatar
Some one asked if the tiger drive would fit the O.S. .18.... It kinda does. I hve a TD on mine but I had to use a shaft from a Racer's Edge starter kit that they no longer make. The starter kit is for the OS engine if you can find it but that kit has some plastic gears that I didnt trust. I then found the TD kit that would fit that engine and shaft combo. I posted about it here once before last summer but I cant for the life of me find it now. It was on a thread about my Miss Elam 1/12 scale boat and I listed the part #s on that thread. So to answer your question more directly yes it can be done but no not in a single kit.
Massey
Old 03-28-2007, 01:43 PM
  #268
THANKS AGAIN ALL,
I took the boat ito the shop today. The owner, real nice guy, called horizon for me. They all agreed, and said it was the con. rod. horizon told him to pull it apart, if it is just the rod that is damaged they will send him a new one to replace it with no charge. If it is more damage to the sleeve/cylinder etc. they want to refurb it at horizon. I believe this will all be under warranty also. I am still going to look for a good price on the .18 in the meantime. The owner of the shop says that he has a friend in Michigan that they modded out the .15 Dyn, and it has been running problem free for over 3 years. I don't know why he lucked out, but... I am worried that I will crack the hull with the pull starter if i put the .18 in there. I have seen some horrifying pics on Ebay !! I hope that they don't have my boat for long. The lake is right outside my front door and is loooking extra slick today I guess I'll have to play with my cheap electric truck in the meantime, or I guess I could quit procastinating in doing my business taxes
[sm=49_49.gif]
Old 03-28-2007, 05:29 PM
  #269
Sean Bowf's Avatar
Tower has a belt start (bump start) marine OS .18 for $85. If you want to get one with a pull start...I would not buy the marine pullstart motor ($170). I would buy the car one ($110) and a marine head ($21.50) for a total of $131.50.
Sean
Old 03-28-2007, 05:34 PM
  #270
misshydro's Avatar
I agree with sean bowf. He's wright about doing the car motor and buying the water cooling head!![8D]
Old 03-28-2007, 08:49 PM
  #271
What is bump/belt start?
Old 03-28-2007, 09:47 PM
  #272
misshydro's Avatar
It's a belt that gos on the crank flywheel and a 12 volts start that your belt goes on to start your boat.Heres the starter[8D][link]http://cgi.ebay.com/Sullivan-Hi-Tork-Deluxe-Electric-Starter_W0QQitemZ160092444934QQcategoryZ34056QQrdZ 1QQcmdZViewItem[/link]
Old 03-28-2007, 09:50 PM
  #273
Sean Bowf's Avatar
I was referring to a motor that does not have a pull start. I think car guys call them bump start. For boats, it means using a belt and electric starter as MH pointed out.
This is the motor I was talking about: http://www2.towerhobbies.com/cgi-bin...&I=LXKGR2&P=SM
Sean
Old 03-28-2007, 09:59 PM
  #274
misshydro's Avatar
That the motor Sean Bowl!! Jay you need to take off your crankfly wheel off the.15 and put it on the.18.
Old 03-29-2007, 04:51 PM
  #275
This belt starting technique seems like it would be even more traumatic to the hull than the pull statrer, and too much extra equipment.
You have a pull on your .18, right MissHydro?
ever had any issues?
BTW, the owner of the shop tore down the engine yesterday, it was just the connecting rod. no further damage to the bearing, sleeve, cylinder, and whatnot. Horizon is sending him the part so that he can fix it under warranty. Soon I will figure something out.
thanks for all the help everyone,
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
