Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
sc 61 engine
Old 04-07-2005, 11:49 AM
pmuff
Default sc 61 engine
can anyone tell me how to start this sc 61 engine please there just seems to much compression for the starter to handle tried loosning the glow plug as well, aslo anyone know what the card should be set. any help would be appretiated
Old 04-07-2005, 05:27 PM
mhols
Default RE: sc 61 engine
Just loosen the glow plug a few turns and when the engine starts just tighten it again.
from fully closed unscrew the needle 2-2 1/2 turn this is just a starting point you might to turn it in if the engine sounds muddy and if the engine slow down at full speed then the engine is sett to lean then you have to unscrew the needle a bit more.
Old 04-07-2005, 11:48 PM
Ron Olson
Ron Olson's Avatar
You might have to go to a better starter or go to a 24 volt starter. The low buck ones won't turn that motor over, sometimes even with a loose glow plug.
Old 04-08-2005, 08:47 AM
pmuff
thks m8 will try soon as i can .
Old 04-16-2005, 09:35 PM
stnstn
take plug out open throtle right up turn over till fuel is poring out plug hole than close throtle spin again to get ride of exra fuel wipe with rag plug in and then go. that gets my old girl spinning tri it it just may work
Old 04-17-2005, 04:39 AM
pmuff
thks m8 will try that engine is brand new and need it running to break in .
