Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
outboard cuts out at top speed
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 04-24-2005, 03:14 PM
r/cmark42
My Feedback: (8)
Default outboard cuts out at top speed
I have a K&B 3.5 outboard with gold carb and tuned pipe. I have attached to a tunnel haul and if the thing had wings, it would fly! Problem..Once it hits top speed, the engine bogs out after 3-4 seconds. any suggestions? I have played with the needle, richening and leaning does not seem to effect this situation
Old 04-24-2005, 03:30 PM
ob nut
ob nut's Avatar
Default RE: outboard cuts out at top speed
I had this issue before. What fuel tank(s) you using? If you don't have a hopper tank, might want to get one of the new ones from Jim Irwin. They are sweet. Other options: Bearings good? Might want to replace the fuel lines. Needle should be anywhere from 3 - 4 turns out. Good starting point is 3 1/2 turns out.
Old 04-24-2005, 03:54 PM
*JCB*
My Feedback: (9)
*JCB*'s Avatar
make sure your fuel tank is properly sealed and you are getting proper pressure from you muffler. sounds like the motor is being starved of fuel, also try giving your carb a real good cleaning and blow out w/ compressed air
Old 04-24-2005, 06:46 PM
Tricksligger
Tricksligger's Avatar
It sounds like a simple case of running too lean. I know you said you tried richening it but maybe you didnt go far enough. If it had to do with your fuel tank or lines it would cut out at any speed. When its just at top speed it usually means your too lean. I dont own a r/c boat...
but....
I did stay at a holiday Inn last week[X(].
Old 04-25-2005, 11:50 AM
r/cmark42
My Feedback: (8)
Thanks for the information, I will start experimenting further this week...
Old 04-28-2005, 07:39 PM
jetpack
jetpack's Avatar
Mine i found out was starving for fuel at speed, cause the stock exhaust didnt have any pressure to it, i had to raise it up as high as i could under the cowl for it to gravity feed better.
Old 04-29-2005, 06:56 AM
r/cmark42
My Feedback: (8)
Well, based on replies submitted, I have cleaned out old fuel tank, installed new lines, removed and cleaned out carb, will raise tank and richen fuel mixture. If this stupid weather clear up, I will let you know soon how it all works out
thanks for all your replies!
Old 05-02-2005, 08:28 AM
Satkunas
Hey I just ran my boat yesterday and I think I have a setup almost like yours. I have a Quickie 40 with a K&B 3,5ss gold head and carb.
I had the same problem yesterday, but as someone said before I went far and now I can say that this engine loves fuel...........
My boat was running almost like yours, at top speeds my engine just die........So I openned the fuel valve 1 and 1/2 turn and now the engine is running perfect !!!!!!!
For start the engine is pretty easy, and until launch the boat in the water, you need to get the carb almost totally open, cause the engine runs too much rich.....but after you hit the water, (with the load in the prop) the engine become full power !!!!!!!!!!
Hope it helps you !!!
Henrique from Brazil
Old 05-02-2005, 10:06 AM
r/cmark42
My Feedback: (8)
Thanks all again.
Went out this weekend with all changes made. I'll be darn if the thing still died out at the top. My neighbor (great guy) had an exrta carb. On a hunch we changed mine out for his. (Gold to Red) Once the red carb was installed it ran sweeeeet!!!
I'm not sure the reasons why, but who am I to argue when something works
