Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Tuning. I suck at it.
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 05-09-2005, 08:52 PM
ejp67
Default Tuning. I suck at it.
I know my cat isn't going as fast as it should. Here are some things keeping it from doing that. I need some Ideas to change that.
I look at most of the cats on the net and it seems that their struts are a little below the bottom the hull. Am I dreaming about that??? I can kick my strut out a little but I am limited because the stubshaft is so long that it makes things get stiffer when I spin the prop after I kick it out to the max. Any ideas??? Am I way off on how my strut should be set?????
Now, my pipe is close to a foot long from the glow plug to the fatest part of the pipe The reason it is so long is because it has to stick out the back of the boat. I want to shorten it to get max rpm's but then I would have to add on the the end. Won't this make the pipe change again
Please help me, I am not good at this tuning thing, just building
Old 05-09-2005, 11:36 PM
Ron Olson
Ron Olson's Avatar
Default RE: Tuning. I suck at it.
Yeah, your pipe is way too long! You should start at 8-1/2 to 9" then dial it on from there. If you have to add an extension to the end of the pipe to get it out of the hull then that's what you'll have to do.
You're going to have to mess with the strut to find out where it's happy at.
Old 05-10-2005, 08:39 PM
ejp67
does this look better????? It still is about 9 inches. I can't cut much more because it gets so fat. what do I do????
Old 05-10-2005, 10:28 PM
Ron Olson
Ron Olson's Avatar
Try it there to see how it runs. Don't cut the pipe any shorter, there is an alternative if you have to get drastic. GS Racing has some couplers that are "J" shaped so that the header can be cut more. I'd use them as a last resort though.
Old 05-10-2005, 10:39 PM
ejp67
Ok. thanks. That should be better then it was anyway. I have a question about another boat. How do I get rid of cavitation??? Bigger/smaller prop????
Old 05-10-2005, 11:10 PM
Ron Olson
Ron Olson's Avatar
Strut adjustment, drop it down a little until it quits.
