Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Tuning my 35 K&B Outboard, 31" Prather...
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 06-12-2005, 12:48 PM
Dallas22
Default Tuning my 35 K&B Outboard, 31" Prather...
At first, it was leaning out on me at top end and would die dead the water if left at WOT for more than 3 seconds. I have opened the mixture screw 1/4 turn by 1/4 turn utnil the problem was fixed but now, it is real sluggish and non-responsive at low-middle speeds. it only runs good at top end. There is only 1 mixture screw on the side of the carb and a small idle screw on the back of the carb. How can this be fixed?
Dallas.
Old 06-12-2005, 05:36 PM
Ron Olson
Ron Olson's Avatar
Default RE: Tuning my 35 K&B Outboard, 31" Prather...
The initial setting of the carb should be near 3-1/2 turns out. K&B recommends 4-1/2 turns out but that's too rich to get it to fire up. The prop might be too much for it or the engine could be set too low giving you headaches. The centerline of your prop ought to be about level with the bottom of the Vee. The Octura X-437 or X-438 props are good ones to start with or a Prather 215.
Old 06-13-2005, 03:26 PM
ob nut
ob nut's Avatar
Besides those Ron pointed out, I'd check for worn bearings or a piston/sleave on their last runs. Most likely that the motor is to deep.
Old 06-14-2005, 06:45 PM
eas___1990
where might a fellow be able to pick a k&b outboard up at?
Old 06-14-2005, 06:49 PM
piper_chuck
My Feedback: (12)
piper_chuck's Avatar
ORIGINAL: eas___1990
You could always go to the source:
http://www.mecoa.com/kb/marine/marine_outboard.htm
Old 06-14-2005, 06:56 PM
eas___1990
thanks chuck
Old 06-14-2005, 10:32 PM
ob nut
ob nut's Avatar
Prices are better at [link=http://www.precision-boats.com/]Precision Boats Racing[/link] or check with krpnova on this site. He works at Phil's Hobby shop in Ind. I'd give his site httm, but not certain which one he works at [&o]
Old 06-14-2005, 10:38 PM
Ron Olson
Ron Olson's Avatar
Bob works at the main store in Fort Wayne but you can also talk to Steve there if Bob isn't around. The web site should be for the main store.
