Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
 CONVERTING A MISS BUD >
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 10-03-2005, 02:55 PM
Default CONVERTING A MISS BUD
Need some of you experts to give me some advise on this one if you would please. I have several boats so I will understand what you advise. The thing is I bought one of the bud 1/12 scale first version boats to do a boat bash job on, as I have one of the second versions now, but want to leave it alone. This early version is the one I want to make some changes on. I bought a Picco TS 125 .15 engine to install which is a car motor and will have plenty of air across the head. This engine is rated at 1.4 HP at 34,000 RPM and is known to be a killer car motor. I was going to change this boat to the flex shaft but wondered if I should leave the stright shaft in it as it might help keep the front of the boat down with so much more power to the prop. What do you think? Also, what kind of rear hardware would you recommend?
Thanks, Chris
Old 10-03-2005, 04:08 PM
Default RE: CONVERTING A MISS BUD
from what ive heard about when people upgrade their bud motor they install a whole new flex shaft and strut setup. thats for people with big motors going in though. you could mount it in the stock spot and the flexshaft might last a few runs.
Old 10-05-2005, 09:38 AM
This bud is the early version and has the straight shaft, and I am going to change it over to the flex shaft but thought I should try it out with this new motor first. With the prop having this slight down angle, won't the nose be pushed down a little? I thought maybe this might help with blow over as this boat should have more speed with this high rpm engine.
Old 10-05-2005, 07:43 PM
Hydro Junkie's Avatar
You're forgetting something. Your high powered car engine runs though a gearbox BEFORE going to the drive wheels. In a boat, you are looking at a direct drive. This means you won't be getting the high RPM numbers and, therefore, the high HP numbers. I'd recommend installing the engine with a QUALITY flex drive system. Plan on a heavier rudder servo, larger rudder and skid fin, as well as having to rebalance the boat. Be sure to get a kick-back type rudder and skid fin brackets. They can prevent serious hull damage if you hit something in the water
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
