Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Finish my NH surface drive but I have a Problem
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 01-28-2006, 08:51 PM
lnc0321
Default Finish my NH surface drive but I have a Problem
I finally finish putting a surface drive into my hammer, but when I finish I noticed that I had turning problems. I also put a new servo (futaba s 3003). My rudder hardly turns. I tried it in my pool and it would turn only a bit. Here are some pics. Please Guys see if u can help. Here are some PICS
ID:	397305   Click image for larger version
ID:	397306   Click image for larger version
Old 01-28-2006, 10:29 PM
330T
Default RE: Finish my NH surface drive but I have a Problem
on the rudder put the pin as far in as you can, give you more rotation per movement. If that does not fix it move the pin on your servo arm all the way out.
Also check your transmitter make sure you dont have the range turned down or something simple like that
Old 01-28-2006, 10:47 PM
wave waker
looks neat, do u have a side view showing the prop?
check ur servo if it's throwing 30 degrees each side.
u may check also the EZ link to the rudder horn should have a play and not be tight...hope these help.
Old 01-29-2006, 12:04 AM
Vertical3-D
My Feedback: (20)
Vertical3-D's Avatar
ok heres the real issue, like said move the connector in on the rudder arm and out on the servo, but the big thing i see right away, make sure that the servo arm is strait out at neutral and that the rudder arm is also strait out, that should help alot.
Old 01-29-2006, 02:05 PM
lnc0321
Thank u guys. I did move the pin as far as it can go in both places and change my servo to the stock one that came with the boat and it looks like it improve a bit. I have to wait until I tested on the water. How far is my rudder suppose to turn? Thanks
Old 01-29-2006, 02:56 PM
lnc0321
here are more PICS of my setup.
ID:	397819   Click image for larger version
Old 01-29-2006, 03:05 PM
lnc0321
PICS
ID:	397828   Click image for larger version
Old 01-29-2006, 04:34 PM
Ron Olson
Ron Olson's Avatar
You might need a turn fin on that boat. Where are your trim tabs?
Old 01-29-2006, 05:02 PM
Vertical3-D
My Feedback: (20)
yup, you'll probablly be needing those, the stock tab and fin combos should work id think, good ron noticed that, i was more concerned bout the rudder and didnt catch it
