Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
my build.... how does it look so far?
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 02-02-2006, 04:26 AM
hyper701
hyper701's Avatar
Default my build.... how does it look so far?
how does this look so far? its my 1st build and i was just wondering if im on the rite track, the boat is 34.5 inches long with a .21 buggy engine, and the engine is 9.2 inches forward of the transom, please your honest opinion would be great
ID:	400352   Click image for larger version
Old 02-02-2006, 05:46 AM
Matty_c
Default RE: my build.... how does it look so far?
nice build i am currently building a gas boat bit i want to build one like your after hope you have fun with it i might not have left any advise cos i probably will need some to any way nice start.
Matty_C
Old 02-02-2006, 06:16 AM
hyper701
hyper701's Avatar
thats funny, i saw your gas boat thread and i want to build one like that after this one
Old 02-02-2006, 07:58 AM
jdoug
Hyper - Looks pretty good to me. Glad to see other builders out there. The ready to runs just aren't as satisfying.
One thing that I see that might give you a problem is the size of your radio box. It looks really small. But, then again I have seen some with tiny radio boxes and they seem to get everything in there. Is your engine mounted? It looks like you might have to lean it towards the back of the boat a little more so that your flex shaft can exit the transom without any weird bends.
Like me, you chose to build your first boat. You'll learn alot along the way.
Old 02-02-2006, 09:17 AM
Square Nozzle
The 3 ply plywood formers that you are using is not a recommended quality for boats. 5 ply aircraft grade birch is the norm. Since you have already built to this stage, be sure that you put several coats of epoxy an all the interior surfaces to keep water from soaking into the wood. That stuff will soak up water like a sponge and fall apart shortly after. I would also suggest that you reinforce the keel seam on the interior with some fiberglass cloth (2 oz cloth is good). Do the same where the transom meets the bottom sheeting. The engine looks to be to far back, you will have a problem getting the drive line in place without putting sharp bends in the flex shaft. It also looks like you will have to run the shaft log through the radio box, further restricting the space you have for the radio gear. With the miniaturization of todays receivers and servos you may get away with it. I'd suggest a very small servo for the throttle and nearly as small for the rudder. A 600 to 700 mah nickle metal hydride battery will also save space. Many people think you need a servo strong enough to open a barn door for the rudder when the opposite is true. A .21 powered boat will do very well with a 40 oz. in. servo. Especially at the speeds you will be seeing. Look at the Hi Tec HS 81 for the throttle and the HS225 for the rudder. They will provide more than enough torque for your purposes.
Just being honest and trying to get you on the right track.
Old 02-02-2006, 10:59 AM
Hydro Junkie
Hydro Junkie's Avatar
Good call on the plywood John. I also agree on the epoxy coating, 30 minute or slower epoxy would be best.
Old 02-02-2006, 07:02 PM
Ron Olson
Ron Olson's Avatar
Before getting too far on the deck, do a test fit of the exhaust and other hardware. The ability to get at things once they are installed can be a problem ot just putting them in after you have finished the hull work could be a challenge.
Old 02-03-2006, 01:34 AM
Matty_c
hey hyper701 if you want the plans for the cracker box iam building ill send em to ya just give me your e-mail. and are you building this deepvee from plans cos if you are could you saned em to me my e-mail is [email protected] thanks.
Matty_C
Old 02-03-2006, 01:39 AM
hyper701
hyper701's Avatar
my exhaust is gona sit on the deck alongside the engine, im just using the buggy exhaust caus ive got a spare one.
i will make sure the hull and all the internals have a good coat of epoxy so i dont get water damage, and the radio gear..... i think the gear im using should fit no trouble. thanks for the feedback, at least i no i am on the rite track
Old 02-03-2006, 01:43 AM
hyper701
hyper701's Avatar
yea matty that would be great my email is [email protected] . i will send u the plans for this boat... well il try....i aint the best with computers
Old 02-03-2006, 01:49 AM
Matty_c
sent em.
Matty_C
Old 02-03-2006, 02:27 AM
hyper701
hyper701's Avatar
cheers mate sent yours to
Old 02-03-2006, 03:32 AM
Matty_c
thanks. your cool1[8D]
PS started my rudder half an hour ago so ill post some pics when done it will be in my post.
Matty_C
Old 02-05-2006, 04:13 AM
hyper701
hyper701's Avatar
ok, i did what u said i put the engine on more of a lean so the flex cable wont have to much of a bend in it, i also cut the servos in to the radio box and it all fits nicely..... i think
ID:	402216   Click image for larger version
Old 02-16-2006, 10:28 PM
fishy2k8
fishy2k8's Avatar
would a heat sink work for a boat? are there advantages/disadvantages?
Old 02-16-2006, 10:39 PM
Ron Olson
Ron Olson's Avatar
Heat sink heads work fine in boats, most of the time better than in a 4-wheeler as they get more air and cooler air coming from off the water. The only downside that the Pro's have found is more loss of speed in the corners than water-cooled heads. I would only use them myself for up to .21's as anything that size and under really don't need water cooling. My .12's run so cool that I took the top 3 fins off a heat sink and it still wasn't getting warm!
The downside also is how the engines come equipped. SG cranks are all but impossible to hook up to a flywheel and flex cable collet. some of the carbs are too small for us. We can use whatever will fit in the hole, the car guys are restricted by ROAR, IFMAR, etc.
Old 08-02-2006, 10:06 PM
AJ DRAGON
Hi
So how far have you gotten on your boat.
