Shockwave 36 help
Shockwave 36 help
Hello
I wonder if someone could help me out as I'm assisting a friend (I'm a car and truck man!) - I'm trying to bolt the engine back into a Shockwave 36 but I'm not sure how the flywheel and collet etc are fitted.
Does the collet tighten right down to the flywheel or should there be some 'float' for the flywheel? The manual seems to show it tightened right down however when I do this it looks as if the the prop will rotate at all times as there is no 'clutch' as such?
Can anyone assist me putting this back together?
Many thanks
Dave
Many thanks
Dave
RE: Shockwave 36 help
Thank you for your help - much appreciated.
One other quick question - the engine doesn't seem to have an air filter on it - is this correct?
Dave
Dave
