common nitro guys need some help
ON, CANADA
hey guys i was wondering if anybody had any info on a starter made by texson? need to know if it can turn a .90 ? ive got no idea all it says is texson on it need some help how much do you think its worth i used it for starting my outboard
ON, CANADA
RE: common nitro guys need some help
I have never heard of that either. Most people usually use 12volt lead acid or similar type batteries (car batteries) for starters Size doesn't matter, just chemistry to provide the needed amperage these starters demand.
Turning over a .90 is a hard task for the cheaper starters. Most of them say they are able to start a 0-.90 size engine, but I find they have trouble with a brand new .60-.90 even @ 24volts.
For my 11cc and 13cc motors I use a 24v starter. It may be possible to start the larger motors with a 12v, but will most likly need to loosen the plug a turn or two to do so. I've heard of folks using a 12v starter on 24v, just need to limit the time the "on" button is pressed.
