ob nut have questions
FL
i just got the K&B SS motor for my new topspeed 2 and i notice that you have the ss on your hot shot just woundering what % fuel you use and how many turns out is you needle i don't want to lean it out to much and what prop are you useing? im useing a x440/3.
RE: ob nut have questions
Using Wildcat 65% fuel on motors. Needle is around 3 1/8 to 3/14 turns out. I'm setting up a TS2 with K&B SS motor but will be using a 3rd channel remote needle also.
