Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Fiberglass Dumas 40" Deep V worth ??
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 03-07-2006, 09:06 AM
AJsToyz
AJsToyz's Avatar
Default Fiberglass Dumas 40" Deep V worth ??
I was just wondering if anyone had an idea what a Dumas fiberglass deep v is worth. I don't know what the kit is. Its has the drive tube installed , but nothing else is done. It is 40" long with an 11" beam. Just curious. I've got it on ebay and someone whats to know what I would sell it for right now.
Thanks !! Andy
Old 03-07-2006, 02:23 PM
ejds66
Default RE: Fiberglass Dumas 40" Deep V worth ??
OFF-SHORE DEEP VEE 40 156.99
Old 03-07-2006, 02:24 PM
ejds66
PRA1011 Prather Off-Shore Deep Vee 40
TECH NOTES
This is the DEEP VEE 40" OFFSHORE Fiberglass Boat by Prather.
The Deep Vee is Designed for 7.5cc (.45 cu. in.) Inboard Engine.
FEATURES: Epoxy fiberglass hull
Factory joined deck and hull
Marine ply motor mount rails
Plywood bulkheads
Foam flotation
Complete instruction booklet with photos
INCLUDES: One Epoxy boat hull
One Plywood transom plate
One Stuffing box support
One Hardwood front rail cross block
Two Wood motor mount rails
Four Tank eye screws
One Plywood tank plate
Two Foam flotation tubes
SPECS: Length: 40"
Beam: 12"
Engine: 7.5cc glow engine
REQUIRES: 7.5cc inboard engine
Running Hardware (PRA1020)
2-channel radio with one hi-torque and one steering servo.
Hatch Cover (PRA1012)
Radio Box Kit (PRA8100)
Cable Collet for 3/16" flex cable, to fit threads on your engine
crankshaft
Exhaust Throttle
Radio box Seals and Push Rods (PRA8115)
Tuned Pipe, coupler, and clamps
Pressure Fitting
Starting equipment
Field and building equipment
REQUIRED 8" Triangle
TOOLS: Sandpaper and sanding block
Drill and bits
Dremel Tool with metal cutter and saw blade
Soldering Iron
1/2" Round file
C-Clamps
Screwdrivers and Pliers
ACCESSORIES
THE DEEP VEE 40" OFFSHORE IS A FIBERGLASS BOAT DESIGNED FOR A 7.5CC INBOARD
ENGINE.
REQUIRES; 2 CHANNEL RADIO WITH ONE HI-TORQUE SERVO AND ONE STANDARD SERVO,
7.5CC INBOARD MARINE ENGINE, RUNNING HARDWARE, HATCH COVER, FIELD AND BUILDING
EQUIPMENT.
Old 03-07-2006, 02:32 PM
ejds66
http://www.*********.org/dumas_hydroplanes.htm
Old 03-07-2006, 02:44 PM
ejds66
Old 03-07-2006, 06:52 PM
ob nut
ob nut's Avatar
ORIGINAL: ejds66
THE DEEP VEE 40" OFFSHORE IS A FIBERGLASS BOAT DESIGNED FOR A 7.5CC INBOARD ENGINE.
HHMMM, wonder how a K&B 7.5 OB got on mine? Boat is built for either IB or OB use. I purchased my DV40 from a friend for $50. He used some weird paint that needs to be stripped off. The motor hadn't be started in several years and the skeg was broken off.
http://www.dumasestore.com/catalog/p...roducts_id=428 - Dumas store has it at $157.
Item Description
Our 40 in. competition deep vee is for either inboard or outboard .40 or 7.5 cc marine engines. Use flex cable drive running hardware kit #2355 for inboard installation. No running hardware kit is needed for outboard set up.
Length 40 inches
Beam 11 inches
Power .40 or 7.5 cc size gas marine engine, inboard or outboard
Running Hardware #2355 .150 flex cable outdrive
Old 03-07-2006, 08:55 PM
AJsToyz
AJsToyz's Avatar
Mark,
I wish I had a good picture of it with me because it matches nothing at the Dumas web sight !! This boat is at least 18 years old.
Andy
Old 03-07-2006, 09:38 PM
ob nut
ob nut's Avatar
Mine doesn't match what the site has either. It's got a full hatch, not even close to the current model. It's too ugly at the moment to post pics of mine..
Old 03-07-2006, 09:43 PM
Ron Olson
Ron Olson's Avatar
ejds66, I don't know why you bring up things that have nothing to do with the subject at hand as he was asking about a Dumas hull, not a Prather.
Why the price was an issue is up to you and who the prospective seller is. You say that you bought it off eBay so that must give you some kind of an idea as to what it's worth to you.
Old 03-07-2006, 11:24 PM
ob nut
ob nut's Avatar
You know what Ron, I screwed up also. Here I am getting links to Dumas when my boat is a Prather. D'Oh.. Boy do I feel like [:@]
Old 03-07-2006, 11:32 PM
ob nut
ob nut's Avatar
Andy,
Does your boat look like this?
It's the Prather Commander, which is the bigger brother to the DV40. If your so called Dumas doesn't look like what is on the Dumas site, you very well may just have a Prather instead. Prather's site has the DV40 at $189.95.
Old 03-08-2006, 10:20 AM
AJsToyz
AJsToyz's Avatar
Mark,
It has dumas in or on the fiberglass inside the boat. It doesn't look like either. I like the pic you showed , thats a nice looking boat. The dumas 40 is not very atractive , the one I have looks better then the pic at the Dumas web sight. [img][/img]
Old 03-10-2006, 10:40 AM
fishy2k8
fishy2k8's Avatar
what size engine does that hull take?
Old 03-10-2006, 05:33 PM
AJsToyz
AJsToyz's Avatar
It had a 7.5 K&B in the mount.
Old 03-10-2006, 06:34 PM
AJsToyz
AJsToyz's Avatar
Ron,
The question was asked because I'm not all that into boats and I'm the one selling it. I had somebody wanting me to end the auction early and wanted me to shoot him a price. My brother purchased this thing years back and I ended up with it.
Old 03-12-2006, 02:54 PM
AJsToyz
AJsToyz's Avatar
Mark,
I spoke with my brother and he didn't like the Deep V either. He said he bought a Scarab. If thats the case , this thing is really old because they don't list any 40" Scarab!! [X(]
Andy
Old 05-01-2009, 01:16 PM
waltprevost
This is the Dumas Scarab 377.
Old 05-01-2009, 01:19 PM
waltprevost
You should get no less than $300 for it.
