Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
PISTON ??
Old 03-21-2006, 09:16 PM
ZX1
Default PISTON ??
what is the cause of my piston if its black [ top of the head ]
Old 03-21-2006, 10:48 PM
ob nut
ob nut's Avatar
Default RE: PISTON ??
From what I've told, too rich of fuel mixture.
Old 03-21-2006, 11:14 PM
FE_Chris
FE_Chris's Avatar
I have only had them turn color like that when the engine is run too lean and gets to hot. You been tweaking that HS needle?
How much smoke do you have coming out of the pipe when you hit the gas? A lot or a little or what? cause you need smoke!!!
ORIGINAL: yz1000
Old 03-22-2006, 12:26 AM
ob nut
ob nut's Avatar
I've taken out black plugs due to starting/running rich, where I was coming from.
Old 03-22-2006, 12:10 PM
ZX1
yep i got smoke . so can i polish this thing ? or do i leave it alone
Old 03-22-2006, 02:49 PM
martno1fan
martno1fan's Avatar
leave well alone do not polish it or use anything like sand paper wire wool etc its probably the oil in the fuel, does your fuel have castor oil in it?.if so thats the culprit!!.when you say black do you mean BLACK or brown?if brown its def the oil and it natural .
Old 03-22-2006, 02:54 PM
ZX1
thanks i use helli fuel its a blackish/brown color
