I have a enya 60
I have a enya 60
I have just brought a enya 60 with no manuals or info with it, I need to know what glow plug it takes and what nitro mix is best to use
Does anyone have a manual for it
RE: I have a enya 60
You'd be better off asking your question in an airplane engine forum. I believe your Enya is an airplane engine, not suited for marine use. Not to say you can't cobble it up, put a cooling sleeve on the head and put a flywheel on it if you can find one. But why????? You're better off getting a specific made marine engine and avoid all of the aggrevation. To answer you original question, a standard long reach non idle bar plug like a K&B plug should be sufficient. I would'nt waste anything more than 10% nitro in that engine.
