Is this boat worth the money
[link]http://cgi.ebay.com/TopSpeed-2-hydro-w-OS-21-outboard-just-add-Tx-Rx_W0QQitemZ6046989417QQcategoryZ19166QQssPageName ZWDVWQQrdZ1QQcmbZView[/link]
I was wondering if anybody could tell me how much this boat is worth on ebay.
RE: Is this boat worth the money
This is the glow powered, radio controlled almost ready to run
Hobbico Aquacraft Top Speed 2 Tunnel Hull Racing Boat in White.
For modelers 14 years of age and older.
This boat is the stock National Champion Tunnel Hull, 1st and 2nd place
in the 3.5 Tunnel Hull class at the
2005 NAMBA Nationals held in Rollingsford, NH July 9-16.
FEATURES: Construction: Prepainted fiberglass
Hull: Tunnel style with strakes that control water deflection for
added stability, water breaks channel water away from hull for
better acceleration and top end performance
Radio Box: Constructed of wood prefinished and waterproof with room
for 3rd servo for optional on-board fuel mixture control
Fuel Tank: 8oz (240cc)
Stand: Water and fuel proof constructed of wood, doubles as a set-up
board and starting station, start side holds hull and secures
engine during start-up flip stand over and it allows setting
correct prop height and thrust angles
90 day limited warranty
INCLUDES: Top Speed 2 Racing Boat with stand, radio box, instruction manual,
fuel tank, fuel tubing, hardware, two decal sheets, roll of radio
box lid tape, steering rods and throttle cable
REQUIRES: Engine: .21 cu in (3.5cc) outboard marine
Radio: 2-channel
Batteries: 8 AA for radio
Building and shore equipment
SPECS: Length: 30" (762mm)
Width: 11.5" (292mm)
Height Without Engine: 5.75" (146mm)
Weight: 2.1lb (34oz) (964g) hull only
COMMENTS: This boat is available in four hull colors;
White-HCAB5010
Yellow- HCAB5011
Red-HCAB5012
Orange-HCAB5013
The winning equipment used at the 2005 NAMBA Nationals included
Aquacraft Top Speed 2 ARR
O.S. Max .21 XM Outboard Engine, OSMG1721
Futaba 3PK Radio System, FUTJ32**
O'Donnell 65% Boat Fuel, ODOP3165
Radio: 2-channel
White-HCAB5010
Yellow- HCAB5011
Red-HCAB5012
Orange-HCAB5013
