cooling prob
cooling prob
hi can anyone help me i have just bought my first nitro boat my prob is the propeller is not forcing the water to the engine the boat is a tiger shark thanks
RE: cooling prob
1st... Is the pipe/s blocked try blowing through it
2nd... What type of water pickup your useing and silicone pipe
Post a picture so we can see what your useing
RE: cooling prob
to the bottom of this message you will see post reply click that then you will be taken to another page.
At the bottom of this text box you will see file then next to it click here to upload images and files, click on it and a box will come up, click browse and then locate where your picture/s are then click upload
RE: cooling prob
It's all related to where the open end of the pick up tube is in relation to the prop. It should be in line with the tip of the prop blade so when the water come off the prop it will enter the P/U tube under pressure. If it's lined up with the hub, then you will get little or no water. Obviously the open end of the tube should be facing forward or at least have a large enough chamfer on it so it is essentially facing the incoming flow.
RE: cooling prob
Here is mine on one of my boats
I upgraded my pipes from brake pipe to these tubes inside diamitor of 4mm
When i first brought the boat it had the brake pipes fitted to it and it had problems keeping it cool so i replace with those tubes, perfect
