Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
shockwave HSN keeps backing out.
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 07-06-2006, 01:59 PM
yeaitsme
Default shockwave HSN keeps backing out.
i was running my shockwave the other day and noticed the top and didnt have anything. i pulled it out and leaned out the HSN and out it back on the water and it worked perfectly. a few laps later it did it again. i did this 4 or 5 times before i just called it a day. is there anything i could do to fix this inconveniece?
Old 07-07-2006, 10:13 PM
weathervane
weathervane's Avatar
Default RE: shockwave HSN keeps backing out.
You can look in the official S W thread. It is about 30 pages, maybe someone has heard of this.
Good luck
Old 07-08-2006, 12:41 AM
yeaitsme
i think ill pass, id be better off going to the hobby shop.lol thanks anyway
Old 07-09-2006, 12:05 AM
Ron Olson
Ron Olson's Avatar
I'm thinking that something might be missing from behind the needle like a spring. One cobbled up cure might be to slip a large piece of fuel line over the needle and its body to keep it from moving.
I've had the same thing (kind of) happen on my .21 mono as it uses an ink pen type of clip to hold the needle from moving. If it wasn't tight against the needle, the vibrations would move it all over the place.
Old 07-09-2006, 01:21 AM
yeaitsme
so i should unscrew it all the way out and see if sumthings back there? and if not put a spring?
Old 07-09-2006, 07:24 AM
piper_chuck
My Feedback: (12)
piper_chuck's Avatar
ORIGINAL: yeaitsme
I don't have one of these engines, but from the pics I found online it looks like the type of needle setup that would have a small o-ring on the needle that would make contact with the needle body. The o-ring would prevent air from getting past the needle as well as providing some friction to prevent it from loosening while running.
