Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Help for small elec motor / shaft joint
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 07-10-2006, 10:44 AM
dpurkey
Default Help for small elec motor / shaft joint
Hello, I'm working on a kid boat with a 380 motor and small 1/16" shaft. I can't find a decent u joint material. I used to use fuel tubing on boats like this but on this one it keeps coming loose. I don't have room to do much else.
Also, if I use a lipo battery will he ruin it by over discharging it? I can't find a small esc with a low volt cuttoff or for that matter reverse which the boy would like to have.
Thanks for any ideas you might have, Dale
Old 07-11-2006, 07:56 PM
ryan_t888
ryan_t888's Avatar
Default RE: Help for small elec motor / shaft joint
ORIGINAL: dpurkey
I've never heard of a 1.6mm prop shaft, so I don't know what to tell you. I have used the "small" fuel tubing on 2.2mm shafts with no problems. In some cases it makes a great flex shaft.
Over discharging a LiPo battery below 2.75v/cell will harm it. Most LiPo safe ESC will cut the motor out at 3v/cell
Use this with your current ESC for LiPo batts. http://www.dimensionengineering.com/LipoShield.htm\
Ryan
