pipe length
RE: pipe length
I'm using the Mac Products pipes set at around 8-1/2" from the glow plug following the path of the exhaust to the fat part of the pipe.
There are couple of pix in my Gallery if they show up. I just tried looking at mine to see what I had loaded and got the dreaded X's in the boxes.
If you need help locating other parts, I've been through that with all of my .12 powered projects.
RE: pipe length
Thanks, Ron!
I'm using the Macs header and pipe also. I'm not sure if I want to put the pipe on the side or the middle. I like the way yours was done with the pipe on one side and the radio gear on the other. Is it pretty well balanced?
RE: pipe length
Yes, it balances out pretty well. This was a Grimracer hull that Mike built for me do that's the way it came.
The servos (Hitec HS 81 MG's)are mounted on the divider so those are almost centered with a small RX and a Hobby Zone RX battery from one of their planes.
