Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Finaly!, i run my jet stream 1000 today! (with some questions)
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 07-16-2006, 04:49 PM
xism
Default Finaly!, i run my jet stream 1000 today! (with some questions)
A great boat no doubt! my first nitro boat
i have a couple of question here. would the large .32 size stock engine be able to spin a larger prop to make the boat faster? IF,
how big prop can it handle before its going to overheating? (anyone with experience here?)
Old 07-16-2006, 06:47 PM
vamp131
vamp131's Avatar
Default RE: Finaly!, i run my jet stream 1000 today! (with some questions)
wow you are lucky i got an 800 with a 3.5cc in it but stops as soon as it go,s in the water
Old 07-16-2006, 09:07 PM
wave waker
ORIGINAL: xism
with ur stock engine u can play prop diameter from 1.5- 1.9, it's kinda trial n' error coz lots of factor need to consider such as prop height and angle, prop pitch, btw, what's the stock prop size?
overheating is not a direct issue with oversize prop coz for me boat will run crappy with oversize prop and u'll get rid of it before ur engine get overheat, just make sure ur getting water cooling...u'll know if u hit the right prop coz boat is pretty responsive during acceleration, no lots of cavitation, engine sounds getting high rpm and boat moving fast.
Old 07-16-2006, 09:57 PM
xism
wave waker, stock prop size is 40x1.6 (pretty small with alot of pitch). and the engine is already water cooled
vamp131, you mean that it stops when u put some speed on it? have u check the fuel screw so the engine gets enough fuel?
(or maybe on the other hand it gets to MUCH fuel?)
