Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Nitro Hammer Engine Problem Solution, Please!
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 07-16-2006, 08:36 PM
khkim0102
Default Nitro Hammer Engine Problem Solution, Please!
Hello, RC guys!
I have a Nitro Hammer by Hobbico Aqua Craft. It used to run bery well. But one day it stalled on the lake while running. I retrived it from the lake.
After that, it continuously dies at the full throttle, while the engine starts well. I checked air leaking, the fuel tube, the fuel tank, the muffler & the connerctor, but they are OK.
Also I disassembled the engine, but everything looks fine. And I richened the high needle. But still the engine continuously dies at full throttle.
I really cannot figure out the reason of this continuous stalling problem at full throttle.
Could you give me any ideas, please? This problem is so frustrating. Your advices will be appreciated.
Thank you so much for your attention.
Old 07-16-2006, 08:45 PM
wave waker
Default RE: Nitro Hammer Engine Problem Solution, Please!
ORIGINAL: khkim0102
Hello, RC guys!
try to get a new plug, and maybe ur LSN needs to readjust, also check ur throttle servo if workin good since it got wet,, check also the pressure tubing,,hope u'l make it.
Old 07-16-2006, 11:13 PM
khkim0102
Thank you very much for your response.
Well, in fact, I changed the glow plug and checked tubing, pressure, and the throttle servo. But still the engine dies at the full throttle.
By the way, what does "adjusting LSN" mean?
Once again, thank you for your attention.
Old 07-17-2006, 06:30 PM
wave waker
ORIGINAL: khkim0102
sorry for that, means Low Speed Needle, it is a screw head like located in the throttle linkage of the engine carb, need a flat screwdriver to adjust, i think 2-2.5 turns from close.
check ialso the 2 bolts holding the header is tight...or maybe a bad fuel.
Old 07-18-2006, 11:58 AM
Nitro Kid
My Feedback: (9)
Nitro Kid's Avatar
It could be too lean, try richening it a little but.
Old 07-18-2006, 02:15 PM
khkim0102
Thank you guys!
I tried what you said, but still it is same. It is very frustrating.
Any ideas?
Thank you fro your attention.
