tunnel hull set up
tunnel hull set up
My friend has a tunnel hull with a KB 3.5, and is haveing problems seting his throtal up. The carb does not have a rerturn spring so he is useing a rod, also when it gets going it slowly cuts out when running it, does anny one know the couse of this? and also can some post up some pics of their set up thanks.
RE: tunnel hull set up
Look at the throttle set up for the Top Speed2:
1. Go to aquacraftmodels.com
2. Click on "Manuals"
3. Click on TS2 Manual
4. Page down till the part on connecting the throttle(I think it's about page 13)
It is necessary to secure the throttle linkage to the engine. It cannot "float" free or every time you turn the boat the throttle will close or open.
JD
JD
