Prop for a 3.5
Prop for a 3.5
Hi I have got a jet stream it was electric but thats boring lol
put in a 15 marine engine os the boat died as soon as i put her in the water put in a
3.5cc still the same im using standard prop 2 blade 40mm i have brand new parts in the full boat still does not run when i put it in the water bought a 8.5cc engine to make an air boat in mite try fit a tiger drive and use it in my boat can any one help me i have not had it in the water since putting nitro in it ahhhhh
RE: Prop for a 3.5
Part of the problem is/was the prop. The one that comes with Kyosho and CEN Racing hulls isn't the greatest as it does have a lot of pitch to it and the design isn't so hot either.
You can try the Octura X-437, 438 or 440, M-440 or a Prather 215.
The plane engine isn't a good option as it isn't water-cooled.
Problem #2 could be that you're trying to run it too lean. You need the needle on the rich side to where you here a slight lag when you blip the throttle then adjust from there.
