Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
SW36 Outboard 3.5 Project...
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 07-30-2006, 10:44 PM
wave waker
Default SW36 Outboard 3.5 Project...
ok guys, my project has just begun, i'm putting K&B 3.5 outboard, got it from ebay expecting tommorow arrival, just removed the prop strut and rudder. This is experimental sport boat to me, any input is very much welcome...thanks..
pics soon to post, unable to upload right now....
Old 07-30-2006, 11:37 PM
Ron Olson
Ron Olson's Avatar
Default RE: SW36 Outboard 3.5 Project...
I'd move the radio box forward to help replace the lost weight of the inboard. You might want to do something with the fuel tank if you haven't done so already.
If you're having problems uploading pix or vid's, www.rcflix.com is now RCU legal. ob nut and I both have pix and videos over there, some of them from previous Fun Runs. It's one of the best sites that I've used to upload videos. Link the shots to here.
Old 07-31-2006, 09:18 PM
wave waker
Thanks Ron...got quick q's, do i need to keep the tabs and fins?
btw, here's the pic, just got my k&b 3.5 engine, after checkin it crankcase was cracked, what's the easy repair for this? the lower unit plate was cut, i do no wat will be the effect on the boat,,anybody?
ID:	499904   Click image for larger version
ID:	499905   Click image for larger version
ID:	499906   Click image for larger version
Old 07-31-2006, 11:42 PM
Ron Olson
Ron Olson's Avatar
I'd just replace the case instead of trying to repair it.
You can leave the trim tabs and turn fins on for now. I've never been too crazy about the turns fins anyway as they should be 90 degrees to the bottom of the hull instead of the sides. I suspect they did that for packaging reasons, to fit in the box better.
I'm kind of worried about the lower unit too as if the skeg hasn't been modded, it is a late `70's, early `80's model that will be difficult to find parts for. Look inside to if it's threaded or not or if you can use the drive off your other OB engine. If not, you've got an oldie there.
I'm guessing that it could have been one pieced together. The SS cannister exhaust was originally used on the old inboards with an exhaust throttle setup, the reason why they still have the holes in the exhaust flange.
The previous owner also whacked some off the cavitation plate, possibly in an attempt to swing a bigger prop.
Old 08-01-2006, 01:57 AM
Raylon
Raylon's Avatar
Good luck with the boat. It will look and perform awesome I know. I know a really awesome boat by me that is an old 30'(Around that length)Cigarette 1 boat that the guy has fitted twin outboard Merc's on it. Not only does it look and sound insane, it flies through the water.
Old 08-26-2006, 08:34 PM
wave waker
project is still alive[sm=lol.gif], here's the update,,,well, i installed an OS motor instead of K&B out of my disappointment[:@], first, it will take sometime for me to get a K&B crankcase to run it, 2nd i gave up tuning this OS in TS2 as my stock tunnel for race, since i got a modified TS2 it's all right for me...
got some pics..expecting to test run this week..feel free for any input, i need more ideas and things to head up...thanks
ID:	513683   Click image for larger version
ID:	513684   Click image for larger version
ID:	513685   Click image for larger version
ID:	513686   Click image for larger version
Old 08-26-2006, 10:22 PM
Raylon
Raylon's Avatar
Looks good. Is it just me or in the very last picture from straight behind does the motor look a little crooked? I think it may jus be an optical illusion. Keep up the work. Lookin forward to how cool this boat is gunna be.
Old 08-26-2006, 10:25 PM
ryan_t888
ryan_t888's Avatar
Looks awesome! Keep the project going.
Ryan
Old 08-26-2006, 11:35 PM
wave waker
[sm=thumbup.gif]thanks guy for the moral support...my mind right now is pretty much twisted from trying to fit all this stuff in one place, i just wanna make this look as a stock SW36 with outboard motor, so far got a little problem installing the throttle cable coz the motor is so close to the transom and there's no much room to move around.
i might use double servo for steering instead of one due to big servo won't fit in the radio box.
Old 08-26-2006, 11:44 PM
[]TEX[]
ORIGINAL: Zelatio
Yes it does. Check your alignment on the motor to the transom, looks like its leaning a bit to port side. Probably could get away with loosening your mount bolts, twisting it and then retightening.
Looks cool.
Old 08-26-2006, 11:46 PM
[]TEX[]
Now that I look at it again with the other photos it may indeed be an illusion. Maybe it's just the angle of the shot.
Old 08-27-2006, 01:00 AM
Raylon
Raylon's Avatar
Yea same thought here. If you line it up with the center one of the three little bumps on the cover above it, it seems pretty lined up.
Old 08-27-2006, 10:50 PM
wave waker
ok guys, Announcing the SW36 is ready to roll!!!![sm=spinnyeyes.gif] can't wait to see this running so i spent most of my sunday completing this project,...i used dual servo for steering(sponsored by TC31 servo), i can't fit the throttle servo in the radio box so i put way out, got hard time figuring out the cable play.. the transom looks like it was hit by a shot gun, lot of holes, so , tomorrow is the maiden voyage, hope i will not flip it coz my electronics are not waterproof yet..i'll post pics and possible video..
ID:	514392   Click image for larger version
ID:	514393   Click image for larger version
ID:	514394   Click image for larger version
ID:	514395   Click image for larger version
Old 08-28-2006, 04:50 PM
ryan_t888
ryan_t888's Avatar
Ver cool, I like the idea of a video.
Ryan
Old 08-29-2006, 10:52 PM
wave waker
i made it ran yesterday, no issue with the set-up, steering and throttle response pretty good, engine pushing the boat with lots of power but needs to tune the prop height angle and also the tabs...the boat is not fast yet, running mid 20's with less than half throttle, i just took it easy...prop used prather 220, 40% nitro
here's some pics and video at YOUTUBE.COM under RCBOAT or WAVEWAKER2, sorry i do no how to attach a direct link, also excuse the quality of video, ,,those kids in the pond did it for me..
more to come![sm=lol.gif]
ID:	515747   Click image for larger version
ID:	515748   Click image for larger version
ID:	515749   Click image for larger version
ID:	515750   Click image for larger version
Old 08-29-2006, 11:40 PM
impulse
I like the 3rd pic, looks almost 1:1
Old 08-30-2006, 12:28 AM
Ron Olson
Ron Olson's Avatar
Just do a copy and paste in here to the link. I'll see if I can find it.
Old 08-30-2006, 02:43 AM
Doubledog
My Feedback: (48)
Doubledog's Avatar
sweetness. No doubt.
Old 08-30-2006, 08:35 AM
Ron Olson
Ron Olson's Avatar
I tried to find your video without any luck early this morning, mostly what I got was that Hydro-Foamie thing.
Old 08-30-2006, 10:59 AM
ryan_t888
ryan_t888's Avatar
Very cool.
To post links, highlight the address bar by clicking it once. (you tube link) Then HOLD Ctrl and hit "C" while holding ctrl. Click somewhere back in to the RCU text box and hold Ctrl again then hit V while still holding Ctrl.
A direct link will apear like this one for you boat.
SW vid 1
http://www.youtube.com/watch?v=-Cimi56-pyY
SW vid 2
http://www.youtube.com/watch?v=4hRaUQ-ue7o
Ryan
