Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Steering torque...
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Steering torque...
Old 08-21-2006, 09:22 AM
jdoug
Default Steering torque...
How much steering torque is necessary on .15 - .18 size vee hull?
Old 08-21-2006, 10:03 AM
Hydro Junkie
Hydro Junkie's Avatar
Default RE: Steering torque...
I would be looking at 75 inch ounce rated servos. It's probably more than what you actually need, but I'm one that would rather not have to worry about stripping out the servo's gears.
Old 08-21-2006, 10:13 AM
jdoug
Me neither...thanks.
Old 08-21-2006, 05:53 PM
Jesus C
On my aqua jet the steering servo is rated at 65oz & it turns the boat with no problem.
Old 08-21-2006, 10:03 PM
Jerry Dunlap
ORIGINAL: jdoug
From testing I have done on AquaCraft products, a standard servo(and they're pretty inexpensive) will work fine for 15 -18 vee hull applications.
JD
Old 08-21-2006, 11:13 PM
Ron Olson
Ron Olson's Avatar
It could depend on what you're putting it in. I've been using Hi-Tec H81-MG's in my monos and 'riggers and they seem to do the job. Any standard servo will work fine if you're not worried about weight.
If you go small, use the metal geared servos as the plastic gears strip easily.
Old 08-22-2006, 05:11 PM
ryan_t888
ryan_t888's Avatar
My buddy has been using a standard servo in his 7.5 OB tunnel for over 4 years. He is able to turn just as good as my tunnel with 110oz's. But since it has been working for many years I can't argue.[&:]
I would go with a standard servo.
Ryan
