O.S. .81 VR-M Marine
maybe some one can help me out here. i have been looking for this motor now for a while and have been unable to find it any where, non of my local hobby stores can get and and i have looked online for a while now with no better outcome , if you can help that would be great. thanks clay
http://www.os-engines.co.jp/english/...e/marindex.htm
sorry could not get a picture to work right!!
MAX-81VR-M ABC
Expressly For power-boat racing
Displacement
13.01cc(0.794cu.in) Output
4.2ps/22,000r.p.m.
Bore
26.0mm(1.024in.) Practical r.p.m.Range
2,500-25,000r.p.m.
Stroke
24.5mm(0.965in.) Weight
914g(32.3oz.)
MAX-81VR-M ABC
Displacement
4.2ps/22,000r.p.m.
Bore
2,500-25,000r.p.m.
Stroke
914g(32.3oz.)
RE: O.S. .81 VR-M Marine
ORIGINAL: claytonrduvall
um , whats another motor that is similar to it, any ideas. thanks again clay
JD
IL
ummm you could try this sight they seem to have some bigger nitro motors.
www.rocketcityracing.com
paul
paul
any body ever heard any thing about the ops .80 or the k&b .80 motors, i just found those and they looked good, did not know how they where any ideas . thanks clay
My Feedback: (12)
SC
I've run the .67 version of the OPS. Ran great until it threw the rod, which also took out the piston and sleeve. The .80 size is also supposed to be good. The CMB that Jerry mentioned would give more power, but it all depends what you want to do.
wow , i found a cmb and about fell voer wit hthe price , but for the money which one would be the best, also i am kinda new to nitro engines
i was just looking on ebay and the cmb 7.5cc has just as much power as the ops .67, and for hte price which one do you think is a better motor, clay
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
I don't know where that guy gets all of his engines at as he's had some older MAC .45's up for auction also. you can tell them by a reversed 4 in the .45 .
Let's start fresh here. You're looking for a nitro boat, right? What type of boat do you want and what size? Do you plan on racing or just messing around with it?
wel ron , i have ordered a 31 inch deep vee boat from barmstomer boats,( i like the idea that he makes all of his own boats and each boat is a little bit different), he said that he sells them with a 7.5 cc nitro motor in them and i asked him if he went bigger would it work out and he said yes, so the smalest motor that i was looking for would be a 7.5cc, i do not plan on racing this boat i just want to build a very fast boat. i like to build boats , i have built a few electic boats from the hull up ,they are manily just for looks and not for speed ( tug and fishing boats) , i also have built a few rock crawlers, which are really fun, again very slow. just was looking for some thing fast and reliable. hope you can help thanks clay
i looked at the macs and i think that they looked good, but then what harware system would you use on that , i would likto use a surface drive if possible. thanks agian
JD
so you guys now think that a 7.5 is over kill for this boat, and i should go with a .21, whats the main difference betwwen the two sizes of motor( besides power and a little weight), what would be bad about it i guess i should ask. thanks clay
I'd say that a .45 is the maximum that I'd drop in there, any more would be uncontrollable. That hull size is best suited for a .21 .
Seeing how you already ordered the hull from Tim, I'd go with a good .21 as it will be a lot cheaper in the long run for not only the engine and hardware but the fuel costs. If you don't already have an electric starter you can look for one with a pull-start. A decent setup will put you in the mid to high 40 MPH range with no trouble.
